180HD power take off parts needed
   / 180HD power take off parts needed #1
Jim Karbowski
I am in need of a double gear and intermediate shaft for a Mitsubishi MT180HD, older SN, PN (gear) 1981 1657 000 (shaft) 1981 1607 001.
I have searched high and low (and in between) with no luck. Can anyone help? Any assistance would be greatly appreciated.
Thanks....Jim Karbowski aci@proaxis.com
   / 180HD power take off parts needed #2
I can supply a new shaft, but have not been able to find to find a used gear since it is not available new.
Hi Lenard,
Thanks for the relpy. I would like to confirm the PN as there are two different shafts for the 180HD depending on SN. I believe I have an older SN tractor (SN decal has been worn off). It is the shaft with two bearings in the rear with a liner in between the bearings. Apparently the newer shafts do no use a liner (I guess it is just a spacer). The PN listed in the manual is 1981 1007 001. If this is what you have I would be delighted. They list the double gear with two part numbers 1987 1653 00 and 1981 1657 000. I think the latter number is a replacement for the older number. Can you confirm this?
How much do you want for the shaft (assuming it is the correct shaft as I don't know the difference between the two)? If you have a parts manual it is on what I believe to be page 59 as I only have FAXed copies and the page number of this page is missing.
Again thanks for your response, Jim Karbowski PH 541.929.6616
   / 180HD power take off parts needed #4
I can have the shaft made either way. I'm out of them presently
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
2016 Ford F-550 Ext. Cab Flatbed Truck (A52377)
2016 Ford F-550...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A53421)
2025 Kivel Forks...
1994 INGERSOLL RAND SD100D PADFOOT ROLLER (A52706)
1994 INGERSOLL...
WB Mower (A50120)
WB Mower (A50120)
