17hp Craftsman Tractor just cranks won't turn over/start
   / 17hp Craftsman Tractor just cranks won't turn over/start #1
Hawkman2k
northern, nj
Craftsman 17hp
After 2 weeks of this seasons mowing, my Craftsman Tractor backfired and then stalled when I engaged the mower deck. I would not restart.
Engine cranks just fine but does not even try to turn over(start).
Since then I have:
  • Changed oil
  • fresh gas and plug
  • replaced gas filter and gas lines
  • installed Brand new carbeurator
  • installed brand new fuel pump
  • had battery load tested
  • confirmed plug is sparking(removed and saw arching)
Any ideas what else I can check?
   / 17hp Craftsman Tractor just cranks won't turn over/start #2
What is the compression like?
Have you or can you make any adjustments to the carb?
Is it possible to pull the valve cover and see if all is good?
   / 17hp Craftsman Tractor just cranks won't turn over/start #3
Bent/broke the pushrods in one of the heads. Clean the valve covers well and pull them off. With the plugs disconnected, spin the motor over while watching the valve movement. Report back.
   / 17hp Craftsman Tractor just cranks won't turn over/start #4
If it is cranking, it is turning over. That is the same thing.
What it is not doing is firing, or running.
Remove the spark plug and spray some ether, or WD-40 in there, reinstall the plug and see if it fires.
If it fires, it's a fuel issue, if it doesn't, it could be spark, timing, or compression.
If it doesn't run on the starting fluid, and you're really lucky, it's just something simple like the key for the flywheel is sheared. That would cause the timing to change, and not allow it to run.
   / 17hp Craftsman Tractor just cranks won't turn over/start #5
Check for sheared or severely worn key in the flywheel. Sounds like ignition timing jumped.
   / 17hp Craftsman Tractor just cranks won't turn over/start #6
Have been through the worn key problem on two engines. It doesn't take much to knock off the timing.
   / 17hp Craftsman Tractor just cranks won't turn over/start #7
One good backfire used to do it on our Craftsman.
The backfire started when the fuel shut off solenoid on the carb bowl started to die.
   / 17hp Craftsman Tractor just cranks won't turn over/start #8
Seen that sheared key a lot on the Kohler engines after backfire.
DEUTZ MARATHON 60KW GENERATOR (A58216)
DEUTZ MARATHON...
2020 CAT D6K 2XL (A55272)
2020 CAT D6K 2XL...
Golf Cart (A55787)
Golf Cart (A55787)
2013 Express 20' Cargo Trailer (A57148)
2013 Express 20'...
2016 FREIGHTLINER CASCADIA (A58214)
2016 FREIGHTLINER...
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
