1700D with clicking/clanking noise in 4WD
   / 1700D with clicking/clanking noise in 4WD #1
RonJ
Fort Worth, TX
I have a Yanmar 1700D that while driving in 4WD there's a clicking/clanking noise in the area of the front axle. Pushing the FEL into a large pile of dirt and trying to move forward results in a much louder noise. Shifting out of 4WD and there's no noise. Any ideas on where to start troubleshooting? Any help is greatly appreciated.
   / 1700D with clicking/clanking noise in 4WD #2
One idea woud be to jack up one front wheel with 4 wheel drive disengaged, turn that wheel listening for noise and also checking for looseness in the knuckle. Nothing shows then try the other side.
   / 1700D with clicking/clanking noise in 4WD #3
What winston said. But sounds like a bad bearing or a tooth on a gear is missing or its clunking in and out of connection on one side??
Thanks for the comments. Soon as the water goes down a bit I'll do some troubleshooting.
   / 1700D with clicking/clanking noise in 4WD #5
Another possibility is that the front driveshaft is missing some of the balls in the CV joint, or that one of the CV joints is heavily worn to a point where it can pop out and "skip", if that fits your symptoms.
   / 1700D with clicking/clanking noise in 4WD #7
there are no u Joints on this tractor. The closest thing is those CV joints that have ball bearings in them.
NEW Wolverine 72'' Skid Steer Sickle Bar Mower (A53002)
NEW Wolverine 72''...
ITEM LOCATION (A53084)
2015 HINO CONVENTIONAL TYPE TRUCK (A52472)
2015 HINO...
Wacker Neuson Diaphragm Pump (A50325)
Wacker Neuson...
Honda EM5000s 5,000 Watt Portable Generator (A50325)
Honda EM5000s...
Ford F-450 Utility Truck (A52748)
Ford F-450 Utility...
