1700 series gear reduction hub coupler
   / 1700 series gear reduction hub coupler #1
jmp1177
Sonora, CA
New Holland 1700
Hi! I bought a 1700 series Ford awhile back and took the gear reduction front hubs off to repair leaky seals. Now I can't get them back on. The joint assembly connecting the axle stub in the hub to the axle stub in the axle housing seems impossible to get on. There seems to be no way to hold it and line up the axle without it flopping out of position. You can't fit a hand in there and you can only see through the small gap while the gear reduction hub is getting close, then nothing. I know there has to be some kind of trick, or special tool to do this. I'm about to the point of taking out the whole axle and taking it to a dealer to put together. Before I get desperate and start shelling out money, could someone enlighten me please? Thx- Mike
   / 1700 series gear reduction hub coupler #2
Got pics?
   / 1700 series gear reduction hub coupler #3
Did you try taking the shaft out of the axle, install in the hub and then stab back into the axle.
No, but that sounds like a good idea! What's involved in pulling the axle?
   / 1700 series gear reduction hub coupler #5
I was thinking pulling the axle shaft, insert the end into the hub, then stabbing the assembly into the axle. You still have the axle shaft to line up with the differential splines, but you can oscillate the hub while turning the hub and engage it that way. It is certainly worth a try.
Alternatively, you take the axle tube off of the center housing, assemble everything as described, then assemble the axle onto the center section.
I'm thinking pulling the axle tube off might be the easiest, I think I'll have to give it a try. Thx again - Mike
   / 1700 series gear reduction hub coupler #7
BTDT. Hang the coupler on a piece of twine, engage the splines, remove the twine just before the casting halves touch.
Done.
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A56435)
2016 RAM 5500...
Heavy Duty Excavator Ripper (Fits CAT 305) (New/Unused) (A59225)
Heavy Duty...
2011 WESTERN STAR  4900 SB (A58214)
2011 WESTERN STAR...
LOT: Steel Work Bench w/Contents, 40" x 75" (A59076)
LOT: Steel Work...
2020 ISUZU NQR BOX TRUCK (A58214)
2020 ISUZU NQR BOX...
NEW Skid Steer Attachment Plate (A59000)
NEW Skid Steer...
