16LA FEL HD Bucket Cutting Edge Replacement
   / 16LA FEL HD Bucket Cutting Edge Replacement #1
jlong
Bronze Member
West Virginia
NH TC35D
I have a 16LA HD Bucket on a 35D. I was wondering if anyone has had to replace the cutting edge on this type of bucket, and what is involved. Mine is pretty worn from using it on the driveway for snow removal.
The bucket edge seems incorporated into the bucket. I am wondering if you are supposed to weld new edge onto the old, or somehow cut out the old? Cutting out the old edge would actually cut into the side of the bucket. What did it cost?
Appreciate any information or suggestions.
   / 16LA FEL HD Bucket Cutting Edge Replacement #2
I assume that you talking about the bucket edge and not the bolt on wear edge.
Are you drilled for the OEM bolt-on edge ?? If so, I'd go to your dealer and price it. Its about 1/2" thick, 6" wide and dual edged so you can eventually flip it. It has countersunk bolt holes for that smooth bottom finish !
If you're not drilled, I'd consider going to the local snow plow and get a length of cutting edge and then drill and bolt it on.
   / 16LA FEL HD Bucket Cutting Edge Replacement #3
Cutter Bar
New Holland's cutter bar is a perfect addition to your HD bucket and around $180 plus the cost of the mounting bolts.
   / 16LA FEL HD Bucket Cutting Edge Replacement #4
I agree with Jim, the cutter bar is great for scraping snow and ice. But for summer, interchange the cutter bar for a tooth bar for digging dirt. I have been told that a toothbar is like a bucket on steroids. (Mine’s on order) /forums/images/graemlins/grin.gif
Airco Tig Welder (A51691)
Airco Tig Welder...
2024 John Deere 872GP Articulated Motor Grader With GPS Package (A52143)
2024 John Deere...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
John Deere 348 Square Baler (NICE) (A50774)
John Deere 348...
2003 Chevrolet 3500 (A50120)
2003 Chevrolet...
CPS 185 KD8 PORTABLE AIR COMPRESSOR (A52472)
CPS 185 KD8...
