16 or 18 ft car hauler?
   / 16 or 18 ft car hauler? #1
Isaac1
I am thinking about buying a 16-18 foot car hauler flat bed style trailer for a few reasons and would like to get your thoughts on the matter. I lack a trailer in this size range at the moment, we have a little 5x8 bumper pull trailer as well as a 24 ft pipe top gooseneck and a 32 ft flatbed gooseneck, the little 5x8 is handy to haul a lawn tractor or other small load, but is just too small for a lot of stuff, and the goosenecks can be a hassle to connect, manouver, etc. Ideally I would like to get a tilt bed in the 18-20 foot range, but I just can't justify spending that kind of money, so instead I am looking at a couple of used 16-18 ft car haulers, the one that seems to be the best deal so far is a 16 ft with 2 ft dovetail, with a wood 83 inch wide deck, it is about 10 years old and is a quality brand name trailer with dual 3500 pound axles(no brakes though, which would be on my upgrade list), fairly new tires, pull out 5 ft ramps, price is about half the price that the same model goes for new with electric brakes. The other one I am considering is similar to the first, but is newer has an 18 ft deck with 2 ft dovetail, has side mounted slide in storage for ramps, not pull out in in place to use and cost about 75-80% of a new trailer. Do you think either of these would be enough trailer to haul a JD 990 with front end loader and a small bush hog or box blade GVRW is shown as 7700 pounds, tow vehicle would be 3/4 or 1 ton diesel truck (crew cab superduty F250, or standard cab Dodge 3500)? Tractor Data shows the 990 at 2,500 - 3,000 pounds, wheel base 69 inches, overall length 123 inches.
thanks for your feedback
p.s. another reason to get a trailer like this is many of the local hardware stores, etc. will only load flatbed style trailers by forklift, trailers with sides much be loaded by hand..
   / 16 or 18 ft car hauler? #2
I have a FEL and 5' bush hog on my tractor. My 16 foot low boy is short by about 4 feet. Bush Hog tail wheel hangs over. Go for 18 to 20 feet.
   / 16 or 18 ft car hauler? #3
18' minimum, 20' is better. I would have bought an 18' 8 years ago, but I had a friend ride along when I went shopping. He was adamant about me buying a 20 foot trailer. I did, and it was the best favor he ever did for me.
   / 16 or 18 ft car hauler? #4
I have a 16' with a 2' dovetail trailer. My tractor is a BX 2350, and when I have my tractor with end loader and brush hog on my trailer, it only has a foot or so left over, and that's a really small tractor. If you can have some overhang you might be ok. Measure your tractor and attachments and see where your at.
   / 16 or 18 ft car hauler? #5
When I was trailer shopping.....I found a great 16 footer (with 2' dovetail) at a good price. Same axels and description as above....but mine has brakes on box axels.
I would rather have an 18 footer....but I have very limited towing needs so it works out good for me.
I seem to get the tractor weight distributed well over the axels....but there is no extra room - fore and af. A brush hog would be hanging over the rear if I hauled all hooked up like that.
I use the trailer for all kinds of things....and mostly have it if I need service or want to do some work at my cabin, etc.
I'd buy mine again at the price I have in it.....but likely would buy longer if I used it a lot.
   / 16 or 18 ft car hauler? #6
I agree on the 18' deck. I am not a fan of Dove Tails so I have a 18' flat deck trailer. Its a low boy and with my 28HP Jinma, FEL, and Bush Hog the thing sticks over 2'. Any shorter I would be in trouble.
Chris
   / 16 or 18 ft car hauler? #7
Something else to consider. If you are going to use the trailer to haul a car at sometime, the standard utility trailer sides and wheel well will prevent you from opening the car door. I have a 16 foot utility trailer and wish I would have gone for a 18-20 foot flatbed. My JD 3320 w/FEL and JD MX5 brush cutter is about 4 ft longer than the trailer. When loaded, it pulls straight as an arrow and doesn't feel overloaded other than not being long enough. With a 18-20 ft flatbed, you loose the side steel (most have stake pockets now ) which will allow you to be able to open the doors of automobiles if you ever have to trailer one.
   / 16 or 18 ft car hauler? #8
i'd go 18.. I have a 16.. 2 more feet would have ALWAYS been usefull..
   / 16 or 18 ft car hauler? #9
I've had both 16' and 18' trailers. The extra cost for the extra two feet on the 18' makes it well worth the difference.
Thanks for all the replies, it seems everyone feels 16 ft is too small.
2013 FOREST RIVER CARGO TRAILER (A45333)
2013 FOREST RIVER...
DEWALT SDS MAX HAMMER (A45333)
DEWALT SDS MAX...
More info coming soon! (A41185)
More info coming...
2018 Ford E450 Cold Car Van (A39234)
2018 Ford E450...
2007 Isuzu FTR Truck, VIN # 4GTJ7F1357F700209 (A44391)
2007 Isuzu FTR...
2016 INTERNATIONAL PROSTAR SLEEPER (A43003)
2016 INTERNATIONAL...
