1586????
   / 1586???? #1
cat2
Bronze Member
What can you tell me about the IH 1586. i want to know everything. I'm looking at buying one. I'm all John Deere though. I want to know everything the good and bad and the ugly.
   / 1586???? #2
Has the 436 diesel in it, they are 161 hp., have self adjusting, wet hydraulic-powered brakes, muffler is under the hood, has an improved TA over the 66 series IH, also the operators cab, if so equipped, showed a big improvement over the 66 series. Had two 12 volt batteries compared to the 6 volt batteries in the 66 series. The most popular tractor of the 86 series was the 1086, IH sold over 50,000 of them. I think all the 86 series were fitted with the water filter which helped with the cavitation problems that were seen in some high houred wet sleeved 400 series engines.
   / 1586???? #3
If you go to the web site redpowermagazine.com you can find out all you would want to know about IH tractors.
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2021 International HV507 4x4 12ft Single Axle Dump Truck (A51692)
2021 International...
New Long Forks (A53002)
New Long Forks...
2015 DRAGON 137BBL DOUBLE CONICAL VACUUM TRAILER (A52472)
2015 DRAGON 137BBL...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
