1533/challenger 265B troubleshooting help
   / 1533/challenger 265B troubleshooting help #1
stumpfield
Sierra Foothills
2005 MT265B
I got a challenger 265B with about 130 hours. It seems to start and run just fine with no sign of any problem. Occasionally, the engine would just shutdown. I can immediately restart and it will continue to running again. It usually happens when I stop for a couple of minutes. It's happening more often lately. Anyone have this problem with their tractor? Any help to figure this out is greatly appreciated.
   / 1533/challenger 265B troubleshooting help #2
When you are stopped are you shifting your weight around in the seat with the tractor in gear, it could be the seat safety switch.
Frank
Frank
Hmm, I got to pay attention next time. Is there some sort the safety switch on the seat?
   / 1533/challenger 265B troubleshooting help #4
Allot of the newer tractors have a safety switch under the seat so the tractor will stop if you depart. On my 1529 it has a switch with a white plastic lever that is actuated by the seat, if you get off with it in gear it will stop. Perhaps your switch is a little out of adjustment and just moving around, shifting you weight is causing it to stop
Frank
   / 1533/challenger 265B troubleshooting help #6
Just another vote for the seat switch, mine gives me trouble often enough that I have a jumper made from a little piece of wire ready to go.
1995 Stoughton Enclosed Dry Van Trailer, VIN # 1DW1A5323SS900663 (A57453)
1995 Stoughton...
2019 Ford Escape SUV (A56859)
2019 Ford Escape...
2007 FREIGHTLINER M2 26FT BOX TRUCK (A57880)
2007 FREIGHTLINER...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A56859)
2004 Fleetwood...
