3-Point Hitch 1520 3pt lower arms
   / 1520 3pt lower arms #1
grainger12002
Platinum Member
Pomfret,Connecticut
yanmar 336d w ldr,Cub,many attachments
Could someone who has lower arms on the 3pt (1520)model measure the distance from the post where they connect at the rear end-to the center of the hole where an implement hooks up. Trying to fabricate and need an idea of the distance or overall length.
Thanks in advance
   / 1520 3pt lower arms #2
Our 1520 Ford is 27" from center-to-center when measuring pin-to-pin on the implement and the tractor rear end. Your lower links will be need to be longer than 27".
Here's why: The lower links have slight bends at each ends. In other words, the lower links aren't perfectly straight. They are reverse-bent so that the links are wider at the implement than they are where the mount to the tractor. (This description was to clarify, rather than confuse.)
2015 Nissan Altima Sedan (A54815)
2015 Nissan Altima...
TANK MANIFOLD (A58214)
2007 FORD F-150 XL TRITON (A55745)
2007 FORD F-150 XL...
2012 Chevrolet Silverado 2500 HD Enclosed Service Truck (A55973)
2012 Chevrolet...
Ford Super Duty Pickup Truck Bed (A55973)
Ford Super Duty...
Portable Restroom (A54865)
Portable Restroom...
