1510D with super stuck right brake
   / 1510D with super stuck right brake #1
metalmole
Fayetteville, NC
YM1510D
Hi all I just acquired a 1510D that needs some love...among other things it needs is to get the right brake shoes unstuck...I have remove the brake cover plate bolts and the linkage....This thing is STUCK, I have managed to drive in a scraper blade and a thin flat screwdriver being careful not to bend the cover...but I cant get the thing to break lose, it will now turn but I realize that is because I have the wheel off and the rear in the air....Any thoughts on where to go from here....I thought if I have to I can drill a couple holes in the plate to try and get some penetrating oil in there and to tap on the shoes a bit.....any thoughts.... Thanks...
   / 1510D with super stuck right brake #2
Will the cam that activates them on the lower side of the cover move? That is where you need to focus your efforts I think as that is what moves the shoes out and into the drum. My guess is that its possibly not letting the shoes go back to rest? Try to tap it forward or to the front of the tractor with your deadblow to take the pressure off the shoes.
2015 RAM 5500 Bucket Truck w/ Versalift SST40 boom -Cummins Diesel - Auto Trans- 4X4 - 72096 miles (A52748)
2015 RAM 5500...
2022 New Holland Powerstar 110 Tractor with Loader (A51573)
2022 New Holland...
BOBCAT 260 WELDER/GENERATOR (A52472)
BOBCAT 260...
Original " OLD ABE " Cast Iron Eagle Statue For Sale..www.youngsauctionil.com
Original " OLD ABE...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
(9) 2 PLUG VALVES 1502 IRON (A52472)
(9) 2 PLUG VALVES...
