1500D repairs
   / 1500D repairs #1
garye5007
Glastonbury, Ct
Mahindra Max 25
Hello! new to this forum and a have some repairs to do to my 1500D.
1st i have to pull off hyd pump (disconnected loader with engine running DOH!) i haven't had to do this before. i assume i just have to disconnect hoses from intake and discharge and remove 4 bolts and it just pulls foward to remove? once i fix that i have a much bigger job. i need to pull front end apart and seee whats broken in the front gears... any tips? or do i just rip into it and see whats up in there? i do my own work on my trucks and boat but i never had any experience with gears like this and i don't really know what to expect (from the breakdown i saw there are lots of seals and bearings in there) this little tractor runs like a champ and i want to fix whats broke. and i kinda have to do it myself.
any advice would be greatly appreciated!
Thanks in advance for your help! Gary
   / 1500D repairs #2
Welcome to the forum!
Might suggest you check out Hoye Tractor, a supporter of the forum. They have parts and repair manuals for your 1500 and probably any parts you may need.
Good luck.
   / 1500D repairs #3
You have a good dealer in Washington State. Buck at EFC can help you with parts and such. On some tractors Hoye has a great online parts manual, which will help you with figuring out what is on the inside. Do you have manuals for your 1500D? If not most of the dealers, Hoye, EFC, and LMTC will put you in business. The front ends are not as complicated as they are intimidating. Just take it slow and observe normal caution and you should be alright.
Mike
   / 1500D repairs
Thanks, ordered service manuel from hoye yesterday!
fixed hyd pump too, sheared key.. i got lucky i have the user manuel for the american version.
thanks for or advice!
Gary
CAT D6C Crawler Dozer (A47477)
CAT D6C Crawler...
2000 Sterling L9513 Winch Truck (A53473)
2000 Sterling...
47 ft. Portable Transfer Dock (A53117)
47 ft. Portable...
2016 JLG 3248RS 32ft Electric Scissor Lift (A50322)
2016 JLG 3248RS...
2015 TEXAS PRIDE  GOOSENECK (A53843)
2015 TEXAS PRIDE...
5TH WHEEL HITCH (A53843)
5TH WHEEL HITCH...
