1500 Transmission or Rearend Problems
/ 1500 Transmission or Rearend Problems #1
Florida_Farmer
Bronze Member
Central Florida
841 Powermaster, TC33D, TC40 DA, Yanmar 1500, Yanmar 2210B, Scag Turf Tiger, Exmark 72" Lazer Z
My 1500 was running in neutral for about 5 minutes(sitting by itself) when it just kicked into gear. Thankfully the brush hog was on it and in the down position so the left wheel just dug itself into a hole in the soft Florida sand.. Whatever caused it now has something locked up - the only gear that works is 4th or 8th. If you let out the clutch in any other gear it will kill the motor.
The shifting forks appear fine and don't look bent, I can't see any broken gears or metal shavings but it's bound up against itself. With the shifter in the neutral position, it won't roll without pressing the clutch. Everything moves in and out correctly including the hi-lo lever and PTO.
Any help / guesses / or next steps to look at would be much appreciated.
/ 1500 Transmission or Rearend Problems #2
Check those shift forks again. Got to be a broken spring pin or missing spring clip allowing one of them to stay in gear.
Dodge 4500 Bucket Truck (A63689)
Dodge 4500 Bucket...
2008 Hino 268 Truck, VIN # 5PVNJ8JV582S51513 (A65563)
2008 Hino 268...
New Webbing Slings, Polyester, 6:1 & 15" (A62679)
New Webbing...
2022 EZ-GO ELITE...
White 6182 12R Planter (A66285)
White 6182 12R...
Bulk Lot of NEW Motorcycle Control Cables - Motion Pro & Biker's Choice (A63118)
Bulk Lot of NEW...
