15" X 20' culvert
   / 15" X 20' culvert #2
Re: 15\" X 20\' culvert
I recently installed a 10 inch x 40 ft. culvert. I used a steel culvert to cross my drive and attached a plastic one to reach a ditch 20 ft away. I don't know what brand they were, I just saw culverts advertised in the yellow pages and went to look at them. I used steel to cross the road because I knew that I could only put 4 inches of chert on top of it and I was afraid that plastic would not be strong enough being that shallow. The plastic pipe had a "bell" on one end which fit perfectly over the metal culvert. I had to do a little grinding on the ragged edges first, but it worked fine. I have another all metal culvert with two 20 ft. sections. I just wrapped some sheet metal around those to make a connection. They probably make some kind of sleeve for that purpose but I have never seen one.
   / 15" X 20' culvert #3
I don't think the different brands will matter. I used to put pipes in for Texas County MO and we bought them where ever they were cheapest. There are or were connectors that you can buy seperate.
   / 15" X 20' culvert
</font><font color="blue" class="small">( I don't think the different brands will matter. I used to put pipes in for Texas County MO and we bought them where ever they were cheapest. There are or were connectors that you can buy seperate. )</font>
<font color="brown"> ~~~~~~~~~~~~~ </font>
I'm needing 5 maybe 6 20 foot joints of 15" diameter plastic double wall smooth bore.
At $116 a joint the cost gets up there.
Any tips on how or where I might find it for less <font color="red">? </font>
   / 15" X 20' culvert #5
</font><font color="blue" class="small">( I'm needing 5 maybe 6 20 foot joints of 15" diameter plastic double wall smooth bore.
Any tips on how or where I might find it for less )</font>
Yep. Check with the road maintenance section of your township/municipality. Around here, they go in with several other towns to order pipe and stuff. By doing so, they can buy/order in quantity and get better pricing.
It was a year or 2 ago but I got the same pipe through them for $4.19/foot ($82.80 for 20' sections) and they delivered (stopped by my house coming back from picking up a load and threw 7 sections off the trailer for me).
Brian
   / 15" X 20' culvert #6
We've got a local store that sells logging tools and equipment and their plastic culvert is pretty reasonable. If you've got a store like this near you, they might be worth checking.
   / 15" X 20' culvert #7
Discount Drainage
Locations in Akron, Columbus, and Cincinnati
Check out their online catalog and see if they have what you're looking for.
John Deere 648G2 Grapple Skidder (A52384)
John Deere 648G2...
OLIVER DAHLMAN LOT NUMBER 244 (A53084)
OLIVER DAHLMAN LOT...
2018 HINO 268  NON CDL 26FT BOX TRUCK (A53426)
2018 HINO 268 NON...
15ft. Diamondback Airboat with S/A Aluminum Trailer (A51694)
15ft. Diamondback...
2022 CATERPILLAR 980 WHEEL LOADER (A51246)
2022 CATERPILLAR...
2002 MANAC 48'  WALKING FLOOR REFUSE TRAILER (A53426)
2002 MANAC 48'...
