daugen
Epic Contributor
Would appreciate some advice. My little Onan/Cummins propane gen in my new rv specs 15/40 oil.
Well that's easy right, 15/40 is everywhere. Sure is, but it says Diesel on every container I've researched, and I use Rotella T5 15/40 in my tractors.
Where I'm getting hung up is the SAE labeling, as all the 15/40 oil I'm finding has ratings for truck use, different lettering than passenger gas engines.
My gut tells me the diesel oil is overkill for the little lawn mower engine in this gen, but I also don't want to ruin any warranty I have. So for first oil change, I will use the oem oil, which is conventional btw. Onan must have someone formulate this for them, who is unknown. I went over every oil in Walmart yesterday and a local auto parts store and not one appropriately labeled oil except for the oem.
https://www.amazon.com/Cummins-3265...ywords=15w40+onamax+oil&qid=1570450436&sr=8-1
I want the highest heat rating since I intend to travel through the SouthWest. For that, Onan is clear on 15/40 use. They also say straight 30W is preferable if low temps are not encountered, but I can't depend upon that, plus it will make the engine harder to start in colder temps. And I'm not sure of anyone making straight 30W synthetic at normal pricing.
Is there any reason why I can't use T5 or T6 motor oil, or Delo, or..., to run in this 3600 rpm propane powered small engine?
Ten bucks a quart just annoys me, like I'm throwing away money to Onan marketing.
Thanks. Drew
Cummins Onan RV QG 3600 LP - 3.6KYFA-26120 - 3.6kW RV Generator LP
Thanks. Drew
