Hey Guys-
After considering my needs, budget and lot and after asking some other questions here. I've decided to leave my large auto workshop at my moms farm in her 24x80 pale barn.
I would like to get my bike stand and tools at my house. So I can atleast work on my bike projects at home. After a lot of reflection I've decided to build a 14x20 or 16x20 shed on reinforced sonotube piers and a 3/4" plywood T&G floor over joists.
I really used this thread when doing my equipment layouts and choosing a size.
12' x 20' Motorcycle Workshop - Planning Stages - The Garage Journal Board
I've looked over the typical storage sheds built on skids around here, typically a 4x6 skid with 2x6 floor joists, then they block the 4x6 at each end and 8' centers underneath. They seem really overpriced for what you get.
Since this shed wont be moved, I see no advantage to building on skids, I'm envisioning more of what amounts to a "deck" with a shed roof building on top. Are there any advantages to using skids I'm not thinking about?
I'm attaching a drawing I whipped up in CAD, the building drawn is 14x20. Basically the design is a double 2x8 "beam" all the way around on the outside, then another beam on the 20 foot length mid way. Then 2x8 floor joists between them on joist hangers, they only span 7' so a 2x8 should be more than adequate.
As drawn I have the piers on 10' centers length wise. My question is should I drop back and put 4 piers on the 20' length so the double beam is only spanning 5' at a time? I have no idea how to size this beam. It not only carries the floor load but also the roof load between them.
So, how do I size that beam, 10' centers? 5' centers? Obviously less piers is less digging, less sonotubes and rebar, and less concrete, but I dont want something that is built subpar or unsafely.
So can you guys help me out here?
Thanks,
Josh
Thanks,
Josh
