14T Baler Problems again....
   / 14T Baler Problems again.... #1
angel in ME
Got the baler out and figured that we would go without a problem and it won't tie a knot, the needles even lose the baling twine some how...we have just been running it through the cycle by hand with no hay in the baler, don't understand it was working fine when we stopped haying last year...:confused2:
Alright one side is tieing beautiful but the other side refuses to tie got about four bails out of it that tied ... hmmmm
   / 14T Baler Problems again.... #3
There are many variables that have to be right for a knotter to tie. If you can get your hands on a manual, any manual for a baler will be very helpful to you as all knotters work the same. Without more detailed information it is impossible to help you diagnose a problem.:confused:
   / 14T Baler Problems again.... #4
Back the tractor RPM'S down and go slow.
   / 14T Baler Problems again.... #5
Are the needles not carrying the twine, or are is the twine making it into the knotter but not tying?
Need lots more info and perhaps a few pics of the knotter/duckbills/needles etc....
   / 14T Baler Problems again.... #7
That is one of the best videos of knotters out there. It has been around for a long long time, but never saw it on youtube before.
Is the twine making it into the twine disc? Make sure your needle is adjust so that it just clears the twine disc, about 1/32-1/64 of an inch clearance. Let us know if this is happening and we can tell you where to go from there.
   / 14T Baler Problems again.... #8
Got the baler out and figured that we would go without a problem and it won't tie a knot, the needles even lose the baling twine some how..:
If needles are losing twine then twine disc isn't holding the tail of the twine or twine is breaking allowing twine to come out of the eye of the needle.
   / 14T Baler Problems again.... #9
In a nut shell ! JD etc knotters work exactly the same. Watch in 420P
That's an excellent video. It's too bad JD doesn't have a video similar to that one. Granted all sq baler knotters are very similar in operation.
   / 14T Baler Problems again.... #10
All are the same. Paint it green and you have a JD knotter.
2020 Gehl RT105 Skidloader (RIDE AND DRIVE) (A50774)
2020 Gehl RT105...
2014 Kubota M8560 (A50120)
2014 Kubota M8560...
2015 Hyundai Sonata Hybrid Sedan (A50324)
2015 Hyundai...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2020 FREIGHTLINER...
