14LA FEL lifting capacities
   / 14LA FEL lifting capacities #1
Dave1953
Claremont, NC
5000 Ford, 2019 New Holland Boomer 55 Cab, 935GBH BH
As I look over the weight lifting capabilities of the 14LA on my TC34DA I see nothing which states if the figures include the weight of the 68" Q/A bucket or not. I am putting a tooth bar on it which weighs 100 lbs and I have no idea what a 68" Q/A bucket weighs but if the published figures include the bucket I won't have as much lifting cap. as I was hoping for. Thanks for any input.
Dave
   / 14LA FEL lifting capacities #2
Loader lift specs are normally expressed as lifting weight at the loader arm pins or 19" forward (because most loads are forward of the bucket). You have to deduct bucket weight from total weight and your bucket without the toothbar is around 250-275 lb. I believe your 14LA has a lift of around 1400 lb, so you can easily lift about 1000 lb with the bucket and toothbar, perhaps slightly more.
BTW: I just use the model of the loader as the rough total lifting power. It is pretty close and easy to remember:
1. 14LA = 1400 lb
2. 16LA = 1600 lb
3. 18LA = 1800 lb
Of course, the next question might be if the 15LA can lift 1500 lb, and the answer is no. It can actually lift slightly less than the 14LA because it it longer to account for the SuperSteer tractor it is mounted on, so it can lift maybe 100 lb less than the 14LA.
Thanks so much for the response. I suspected the weight carrying figures did not count the bucket. Thanks.
Dave
2008 Jeep Wrangler Unlimited X SUV (A53117)
2008 Jeep Wrangler...
MAH QUICK ATTACH MAST W/ 48" FORKS (A51246)
MAH QUICK ATTACH...
2025 SDLANCH SDLGC80 UNUSED Electric Golf Cart (A53117)
2025 SDLANCH...
JOHN DEERE 608C LOT NUMBER 19 (A53084)
JOHN DEERE 608C...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
2001 John Deere M665 (A50120)
2001 John Deere...
