1440V keeps blowing fuse on headligfhts
   / 1440V keeps blowing fuse on headligfhts #1
firemailwv
Sissonville, WV
Kubota BX25D
Any ideas where to check first? the lights will work for a few minutes, then the fuse blows. I gave a quick look visually but didn't see anything that would be causing it.
thanks
   / 1440V keeps blowing fuse on headligfhts #2
I had to Google a 1440V, sounds like you have a Massey. Maybe a little more info would help. Did you change the headlights recently? Or did the fuse just start blowing? If you changed the headlights, check for a short to the frame somewhere around the lights. If the fuse just started blowing and the lights work each time until the fuse blows, you have a short somewhere betwenthe switch and the lights. Maybe even in the switch. If you have a schematic or can trace the wires, take the wire loose at the switch and check if the fuse blows. Then connect the switch back up and disconnect at the lights, try the fuse again. If it blows then you have a short in the wire between. If you have a multimeter you can check with it as well.
DEWALT 3400 PSI GAS PRESSURE WASHER (A51248)
DEWALT 3400 PSI...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2024 JOHN DEERE 9R440 LOT NUMBER 210 (A53084)
2024 JOHN DEERE...
UNUSED AGT YSRT14 STAND-ON SKID STEER (A51247)
UNUSED AGT YSRT14...
UNUSED HURRICANE D6028 - 5' JOB BOX (A51248)
UNUSED HURRICANE...
ECHO CS4010 CHAIN SAW (A51248)
ECHO CS4010 CHAIN...
