1433V and plowing.
   / 1433V and plowing. #1
mark4Jesus
Sale Creek, TN
2021 Branson 2610h
Can my 1433 pull a two-bottom plow? I have a single now, two-bottom would make things go quicker!
   / 1433V and plowing. #2
Yessir, it'll handle it just fine. I can pull a 16" two bottom with my 1533 in 2wd no problem, and the furrows are just the right width for easy plowing.
   / 1433V and plowing. #3
It will pull that size of plow very easily.
   / 1433V and plowing. #5
WilliamBos said:
So our 1523 should be able to handle a 2 furrow Dearborn too then??
Your tractor will be too small and light.
Thanks guys! I didn't want to go out and buy something only to find out it no worky!
WilliamBos, the frame size on you tractor is smaller than the 1533/1433. I orignally looked at a 1528, but decided on buying my low hours 1433 because of size/weight.
2013 Ford F-550 Altec AT40G 40ft Bucket Truck (A50323)
2013 Ford F-550...
Selco V5-HD Vertical Hydraulic Baler (A51691)
Selco V5-HD...
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
1999 Case International MX200 Tractor (RIDE AND DRIVE) (A50774)
1999 Case...
2022 Kubota B2601 (A50120)
2022 Kubota B2601...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
