1428v hydro gear select problem
   / 1428v hydro gear select problem #1
GaryS
franklin park, pa
Kubota L3901 & LA525
I have a 1428v hydro and have about 28 hours on it. The gear select lever has shifted positions and wonder if this is something I can handle or if it's something to get the dealer to fix. As you all know, the lever positions are "(hi) (neutral) (low) (medium)" but now on my tractor, the tractor is in neutral when in the (hi) position and the other selections are shifted forward too.
Anyone know if that's adjustable in the lever linkages or is this symptomatic of some bigger problem?
   / 1428v hydro gear select problem #2
GaryS, I would call the dealer and ask him first, I supposed you have already looked at it to see if a set screw is loose on the shaft or something similar to that...HMMM /forums/images/graemlins/confused.gif
   / 1428v hydro gear select problem #3
I believe there was a dealer service bulletin just released on this subject. /forums/images/graemlins/cool.gif
Wow -- thanks for the info! I love this site. I just called the dealer and he's checking on the bulletin.
The dealer finally got all the parts and came out yesterday to fix the problem. It's working perfectly now. It feels much better - more solid - when I switch gears. I'm really glad they made the change.
The dealer said I knew about the service bulletin before they did!
Again, thanks for the info.
2010 Case 650L Crawler Tractor Dozer (A50322)
2010 Case 650L...
(INOP) CATERPILLAR 259D SKID STEER (A50459)
(INOP) CATERPILLAR...
2007 Terex RS350 Soil Stabilizer/ Reclaimer (A49346)
2007 Terex RS350...
Craftsman T1800 42in. Riding Mower (A49346)
Craftsman T1800...
John Deere 1025R Tractor (A50514)
John Deere 1025R...
AUCTION STARTS HERE @ 9AM (A51406)
AUCTION STARTS...
