Verticaltrx
Veteran Member
- Joined
- Dec 30, 2009
- Messages
- 1,908
- Location
- VA
- Tractor
- Kubota B3200/L2501/SVL65-2/U35-4, IH 454/656, Ford NAA, Case 1845C/480E/450C LGP
I'm getting ready to put a new set of axles under my old 18' 4-ton lowboy trailer and would like to stick with the 8-14.5" mobile home type tires. I like that they are short, but have a huge load rating. The new DOT approved ones are load range F and carry over 2800lbs per tire, making it ideal for a trailer like this.
My dilemma is that I want to use regular 3500lb trailer axles which of course use a standard 5-lug wheel instead of the bud-type wheels that originally came on the trailer. So, does anyone make a 14.5" wheel with a 5 on 4.5" bolt circle? If not does anyone make a bud-type hub that fits on a 3500lb Dexter axle spindle? I believe that Dexter does still make a DOT legal 4000lb axle with bud type wheels but I'm sure it's not cheap. Also I already have a set of 3500lb axles from another project, so I would like to use them if possible. Thanks for any input.
