1300D
   / 1300D #1
klawson44
Virginia
Just picked up my 1300D, I cleaned and changed everything, tractor looks and runs great. I have a couple of question, the two dash lights on the left side (from drivers seat) the little lables are gone, I assume one is Oil one is temp?? Is that correct? Also, does the 1300 have a water pump or should I mix the antifreeze 30-70?? Also, is there an american equiv. sticker kit? It would be handy to put the english stickers on, is this doable? Thanks for any and all help... Got to go till some gardens now...
   / 1300D #2
Yep, oil and water. The one that comes on when you first start the tractor is the oil. Cooling is by thermosiphon, no pump or thermostat. 50% antifreeze max. Be sure to clean the radiator outside with a hose from the fan side. Flush the inside of the radiator every few years if it is getting too hot. And it helps to use the Yanmar radiator cap.
Great little near-bulletproof tractor.
   / 1300D #3
2006 MACK CV713 KILL TRUCK (A52472)
2006 MACK CV713...
2005 TerraGator 8104 (A52748)
2005 TerraGator...
MI-T-M PRESSURE WASHER (A52472)
MI-T-M PRESSURE...
2018 Chevrolet Tahoe SUV (A51694)
2018 Chevrolet...
2016 Kenworth T270 Truck, VIN # 2NKHHM6X1GM110171 (A51572)
2016 Kenworth T270...
Kawasaki NR (A50324)
