1300d tranny
   / 1300d tranny #1
mnyanmar
The stick on my 1300d got real sloppy and was slipping around. I removed the boot at the bottom of the stick and found that a pin or clip had broken or was worn off. The question I have is does a pin go all the way through the stick or is it a clip that comes from each side and goes in the holes. The purpose of this pin or clip is to allow the stick to move front to back and from side to side without moving all over the place.
   / 1300d tranny #2
mnyanmar,
I don't have a parts manual for the 1300, but the parts manual for my 1301 shows two roll pins going through the ball pivot and the stick - one inside the other. They are listed as 3mmx40mm for the innner, and 5mmx40mm for the outer. So the 3mm one goes inside the 5mm one.
Yanmar part numbers are:
3mmx40mm roll pin 22351-030040
5mmx40mm roll pin 22351-050040
Hope this helps.
2013 John Deere 6105D (A50120)
2013 John Deere...
2017 John Deere Gator TS Utility Cart (A50322)
2017 John Deere...
2015 INTERNATIONAL PROSTAR TANDEM AXLE MID ROOF SLEEPER (A52577)
2015 INTERNATIONAL...
2015 Ford Fusion Sedan (A50324)
2015 Ford Fusion...
