1300D Heat indicator
   / 1300D Heat indicator #1
klawson44
Virginia
My indicator light comes on after 10-15 minutes, it is not hot, I can not imagine it is overheating. Is there an easyway to check the indicator's operation?? Any other ideas??
   / 1300D Heat indicator #2
If the tractor isn't boiling over, it is probably a bad temperature sender. That part is known to fail after a couple of decades, and it usually does so by indicating overheating like you say. I can't think of an easy way to check the sender because it normally doesn't close until well above the boiling point of water. Some of the guys tried things like submerging the sender in hot sugar or oil solutions and measuring the triggering temperature with a candy thermometer. You might try that. Or better yet, just replace the sender with a new one. They aren't expensive and will probably be in stock at most dealers. Or you can do like I did on my YM165D (about the same tractor), and replace the indicator light with a real automotive temperature gauge.
   / 1300D Heat indicator #3
I think your 1300 has the thermosiphon cooling system. If it hasn't been flushed out it might be a good idea. Are you using 30/70 mix antifreeze? Is the outside if the radiator clear? It's a real good idea to keep the cooling system in top shape.
Chris
2013 Chevrolet Caprice Sedan (A51694)
2013 Chevrolet...
2022 INTERNATIONAL MV607 (A52472)
2022 INTERNATIONAL...
2011 DODGE RAM 2500 (A52472)
2011 DODGE RAM...
2006 Imperial 14Ft Flatbed T/A Equipment Trailer (A50324)
2006 Imperial 14Ft...
2001 Ford F150 (A50121)
2001 Ford F150...
2008 JACK  130BBL (A52472)
2008 JACK 130BBL...
