Boeing
Platinum Member
Guys, I have (3)300 gal water tanks just slightly above the grade of my building. It connects by "hose" to an outdoor faucet then plumbed to a 12V impeller type pump. I don't know if the pump would "suck" the water in or not since it is just slightly lower than the tanks it might be gravity. Anyway, it provides remarkable flow and pressure for my shower and sink and even cuts off when pressure is up. (must be some kind of internal pressure switch) When I shower it runs almost all the time, when I use sink it cycles every 4 seconds or so.
A friend suggested a pressure tank but others say that this pump is made to cycle?????
What I'd LIKE to do is replace the 300 gallon tanks with an UNDERGROUND cistern....to prevent cold weather issues every fall. As you probably guessed from the 12V comment above, I have no electricity......SOLAR panels and batteries. I would need a submersible 12V pump that could lift the water from the bottom of the cistern tank (8' or so) WITH some pressure switch to turn it on and off. Would this submersible pump provide pressure for the shower? Or would I still need the impeller pump inside?
Right now I TANKER this water in and would like to use my gutters/rain to fill the cistern....leaves and pine needle problems. Screen/filter of some sort? Ideas here?
I use this water to shower, brush teeth, wash dishes etc. I DO NOT drink it. I pretend that if I spit it out I can't get sick. (been ok so far) BTW, I add a cup of Clorox to my 300 gallon tank every filling and a tank lasts me more than a month.
IDEAS would be welcome........Thanks
