12v Solenoid Valves for Rear Remotes
   / 12v Solenoid Valves for Rear Remotes #1
dkhntr04
Northern MN
Deere 3720 Cab
I'm looking for options for 12v solenoid valves to run rear remotes on my McCormick CTV28. Need an open center, work ports closed in neutral, 3 position valve that will handle 5.8 GPM. I bought an 8 GPM Wolverine manual valve, but can't find a spot to put it that I really like. If I can go electric, I can mount everything on the underside of the tractor and keep the install clean and keep the hoses and such away from the operator.
Currently the front runner are these valves from Surplus Center. Surplus Center - 12 VDC 10 GPM OC DA SOLENOID VALVE
2 valves with subplate and connectors is going to run about $360 plus S/H.
Are there other options out there that you know of for 12v valves? Thanks:thumbsup:
   / 12v Solenoid Valves for Rear Remotes #2
Sounds like you have it covered. Those valves are either full on or off, no feathering.
   / 12v Solenoid Valves for Rear Remotes #3
Sounds like you need tandem center valves with a series circuit manifold. Both can be found at HydraulicStore.
Tandem Center D03 Valve, DIN, 12VDC (Includes Connectors)
Series Circuit Manifold (No Relief)
All for $310.60 + S/H.
Good luck! :)
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A52705)
KNOW BEFORE YOU...
78'' skid steer bucket (A53421)
78'' skid steer...
2011 FORD F-450 (A52472)
2011 FORD F-450...
Tennant 800 Ride-On Street Sweeper (A53421)
Tennant 800...
2013 W-W TRAILER ENCLOSED TRAILED (A53843)
2013 W-W TRAILER...
1987 Ravens 45 ft. T/A Float Trailer (A53117)
1987 Ravens 45 ft...
