12V glow plug wiring question..
/ 12V glow plug wiring question.. #1
atsah
Elite Member
Maine/Florida
John Deere 3025E
I’m working on an old Bolens and the glow plugs aren’t getting power from the switch, it has no relay and the fuse is good, my question is, I have a 30amp momentary switch and was wondering if I could put power and ground from the battery to the switch and power the glow plugs with the switch instead of replacing the ignition switch?
/ 12V glow plug wiring question.. #2
Most folks "back in the day" just used a Ford starter solenoid & a push button.. but yes.
It's the easiest and cheapest way to do it, I have all the parts to do it hanging around in the shop. The ignition switch is a bear to change out and I'm afraid I'll break old things trying to get it out..
/ 12V glow plug wiring question.. #4
I suggest you approach this in an organized fashion. Do you have a 12 volt test light like this one? Less than $10
Any chance you have a wiring diagram? If you don't, suggest you post photo of the glow plug side of your engine.
Glow plugs could be wired in series or parallel and it makes a big difference in determining what could be wrong.
Usually, there is a Glow Plug indicator wired in series or parallel with the GP's. While the indicator is giving the owner info, it is also moderating the current flowing to the GP's. The indicator will be a tiny open coil of wire that will turn red as you heat the GP's
GP manufacturers advise against applying 12 volts to their GP's and if you do so you risk part of the GP tip breaking apart inside the engine and the consequences of this can result in a destroyed engine.
On older engines, often GP's don't work because rust has destroyed their ground to the engine block.
Dave M7040
/ 12V glow plug wiring question.. #5
A test light wont show you if your glow plugs are less than 30a.
/ 12V glow plug wiring question.. #6
I'd pull the plug on the ignition switch, and check for corroded connections first!. then I'd check each glow plug with an ohmmeter for continuity, and replace any that are bad. getting the wiring diagram is a must have, you don't want to either spend too much time on this repair, OR damage your glow plugs..
/ 12V glow plug wiring question.. #7
I think best thing to do is validate GP wiring with manufacturers wiring diagram.... Unless you you are really confident in glow plug type (series/parallel 6V/12V) and how its wired (you electrical knowledge) ...
Dale
/ 12V glow plug wiring question.. #8
No it won't but it's about the best elemental trouble shooting tool available.... Have several volt/ohm meters in both analog and digital (one worth $250) and first tool I grab is $5 test lamp....
Dale
/ 12V glow plug wiring question.. #9
Does it have one of those dash mounted indicators, I call them cigarette lighters?
/ 12V glow plug wiring question.. #10
My 2003 Century 2535 has been giving me issues with the wiring and trying to start it for the last couple of years. It would take me awhile to find the problem, and then once I fixed it, something else would go out on it and I'd be back to searching for the latest issue. Finally I had enough and I took out all the wiring and just installed the basics. A new key to the starter and alternator. A push button to the glow plugs. A choke cable to the lever that kills the engine fuel supply.
To start my tractor, I turn on the key, pull out the choke cable and hold the glow plug button for a count of ten. Then it starts right up. It's a little cold, so I rev up the engine for a little while until it warms up. Every time I've wanted to use my tractor, it's started right up. Compared to the last couple of years, this has been a huge improvement!!!
/ 12V glow plug wiring question.. #11
You need to install a relay. Relays carry heat loads better than switches. If I understand what you are saying you are wanting to run a hot wire to the glow plugs keepin them hot all the time. This could cause a catastrophic engine failure if a glow plug melted from constant heat and broke and fell in the engine.
Glow plugs do not need to be engerizered more than 8-10 seconds at a time, not constantly.
/ 12V glow plug wiring question.. #12
That wasn't my take on it at all. He just wants to bypass his "suspected" bad keyswitch with another stand alone switch.
Bingo..
I have a test light and a DVM. I removed the plugs and ohmed them out, .07ohms on each one, so I think they are good. There is a light on the dash but no relay at all in the circuit. The plugs are connected with a buss bar, the power wire comes from the ignition with a tap to the dash light on a 5 amp fuse straight to the furthest glow plug. I get about 9V at the glow plugs but not all the time. The glow plugs look new and heat up fast if I put 12V to them and take it away quickly so they are good.
Dave M7040
I have the test light and DVM see above post, I don't see any tiny open coil. I do have the wiring diagram..
/ 12V glow plug wiring question.. #15
I have a Fluke DC clamp meter (Uses Hall Effect Technology). It's great for troubleshooting stuff like this, albeit a bit expensive.
I would use a HD starter type push button switch and avoid the relay provided the switch can handle the current. Why make things more complicated?
Does the top of the plug itself get warm after you turn the glow plugs on? I just put an electronic temp gauge on the top of the plug and the temp did not change..
/ 12V glow plug wiring question.. #17
Burnt connection in your switch if your key switch controlls it all. Your battery should have 12.7 volts, you are only getting 9 volts on the buss bar if you cant find a resistor or have a deeply discharged battery. That 9 volts may only be fractions of an amp, not enough to feed the plugs load. If there is not a special position in the key switch to activate the glow plugs (buss bar) then would there would have to be a relay and some sort of controller in there that would operate the relay to keep them from being on full time. The glow plug conroller would have some sort of timer that ran the glow plugs for a predetermined time based on the engine coolant temp.
/ 12V glow plug wiring question.. #18
I'm thinking that whole thing should see a rise in temperature with the current that should be going through there.
I wonder if I have a grounding, maybe I should put a ground on each one and see if it gets hot..
/ 12V glow plug wiring question.. #20
It's why the element in the dash was such a good, simple and engenius idea. Presumably it was in series, and if it glowed, you knew the plugs were getting warm too.
UNUSED WOLVERINE SB66 - 66" ROCK BUCKET (A64281)
UNUSED WOLVERINE...
2006 Mack Granite CV713 Dumping Flatbed (A62679)
2006 Mack Granite...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2000 Bobcat 763 (A60462)
2000 Bobcat 763...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2018 Ford F-150...
2716SFL (A61567)
2716SFL (A61567)
