12V DC Transformer
   / 12V DC Transformer #1
RayCo
Veteran Member
Chester County, PA
Kubota BX24, Case 580 Super L
For years, I have casually looked for a decent 12V DC transformer that I could put in my garage so that I could run 12V DC power to various locations throughout the garage along with the standard AC power that exists. There have been many times that I wanted a 12V source and wound up just going to the nearest car or tractor battery.
In looking for a solution, I've found 12V transformers that only put out 1 or 2 amps. This is no good. I'd like a MINIMUM of 30.
I was able to find higher amperage transformers when going the route that a high school physics teacher might go for classroom equipment purposes, but as I recall, everything was very expensive.
I've considered using a medium-duty battery charger, but I don't get a good feeling about leaving such a thing on 24 hours a day.
I've considered using a car battery and charging it when need-be, but this is pretty junky solution.
Anyone have any thoughts or suggestions?
   / 12V DC Transformer #2
Ray, what do you want to power with 12V DC? I would think the battery charger would be an excellent choice and easily portable to any location.
BTW: There is no such thing as a 12V DC Transformer. All transformers are AC. What you want is a 12V DC Power Supply. The small plug-in 12 volt power supplies are sometimes called transformers, but they have a transformer and at least a bridge rectifier in that case. Some have regulators too. A bench-type variable DC power supply could be used for any DC voltage level you need. I'd consider one of those if you have serious needs at different voltage levels.
   / 12V DC Transformer #3
If you use is for short periods of time, consider a 12V marine battery (deep cycle) and a trickle charger/maintainer. You can get a Schumaker battery maintainer available at Wal Mart for under $30. A battery maintainer like this one only puts out a couple of amps and will shut off when the battery gets fully charged. Since it continuously monitors the battery, it will start charging again when the battery drains back down. Compared to standard trickle chargers, they are designed made to be continuously hooked up to batteries for very long periods of time.
A typical marine deep cycle battery is around 100 Amp/hours, so you could run a 30 Amp load for about three hours.
You can buy both these items for close to $100 and the battery, if properly maintained, should last 4 plus years.
   / 12V DC Transformer #4
I use an old Lionel train transformer... it has different voltage taps on the back and the thing weighs about 12 pounds.
   / 12V DC Transformer #5
I have researched and priced 12 dc power supplies. No thanks. I did what Gary said, a 12v marine battery. I could replace it every 3 years for the next 20 years and still be ahead on money.
   / 12V DC Transformer #6
I am glad that you found a way to do what you need. You probably could have taken a variable ac transformer and then took the diode pack out of an alternator and made what you need. You can pick up variacs (variable ac transformers at swap meets and flea markets sometimes for a few bucks. You did not tell us what you you were going ot use it for. Different things need different amounts of regulation and filtering capacity. Using the 12 volt battery gives you almost pure dc. If you use it without the battery charger attached you will have no ac ripple. Using the trickle charger wont make enough difference for you to be able to detect without some very good test equipment so it really wont make a difference. The better battery chargers with the wheels on them and start capabilities will give you the power you require with some filtering caps on the output they can give pretty clean dc power. If the battery does not work out message me and I can tell you what you need to do
I am not real worried about it but I should point out that if you are keeping a battery under constant charging there is a possibility of it giving off gas and being an explosive hazard
   / 12V DC Transformer #7
If you decide to set up outlets in the shop, look at boating supply catalogs for all types of 12v outlets. You can have them mounted flush on walls, locking caps, etc. There are lots of choices out there in plastic, stainless, etc. BOAT-US or West Marine are good places to start looking. They have outlets, circuit breaker boxes, wiring, busbars, fuses, mini panels, faceplates, etc.
A marine battery with proper wiring would be fine for a permanent installation with attached slow/intelligent charger. A typical 21' boat can easily have a couple hundred feet of wiring in it. Use common sense and have everything labeled, bundled and clamped so it looks neat and professional.
   / 12V DC Transformer #8
If you go the battery route, make sure you have a fuse at the battery to prevent the leads from causing a fire in teh event of a short.
Also, you might want to purchase either a maintenance free battery or a gell battery ( Optima) so that you wont have to worry about electrolyte levels.
Thanks a lot for the replies. I will look into the marine solutions. I do indeed want to have 12V receptacles of some kind (even just spring-posts and cigarette lighters would be fine) throughout my garage for any number of things that come up.
Not that this is the only thing, but I have old car stereos lying around that would be better than the 1980's boom box I have setup. Also, most electronics like cell phones and things these days have 12V chargers made for cars. This would allow me to charge things in my proximity without disrupting my normal charging location in the house.
   / 12V DC Transformer #10
Ray Co, if you looking for a cheap 110 ac to 12 dc power supply consider one from a wrecked RV. Many of these will give the 20 amps dc you are looking for.
However, if want to keep the AC ripple down you will have to put a 12v battery in parallel with the load to flat line the voltage. For low amp requirements with minimum ripple a 12v power supply would be your best shot.
cheers,
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A52377)
2007 Reitnouer 40...
CABINET OF HOSE ENDS (A53843)
CABINET OF HOSE...
UNUSED Polyester Arborist Outdoor Rope (A53117)
UNUSED Polyester...
PALLET OF SCAFFOLDING (APPROX. 21 PC) (A52706)
PALLET OF...
LINDE H70 FORKLIFT (A53843)
LINDE H70 FORKLIFT...
2005 DRAGON PRODUCTS 130BBL VACUUM TRAILER W/CHALLENGER VACUUM PUMP (A53843)
2005 DRAGON...
