Im in a little trouble and could use some help. Im converting a Farmall H 1939? to 12v. I bought a kit. It has No instructions. everything is wired. BUT I cant get voltage to the coil. by the way the coil is not the black round type type with the coil spark wire coming out the top. it is built into the distributor with one wire screwed in the side. Where can i find a reliable wiring diagram to follow to make sure its correct? also, when I wired the resistor in series with the wire to the coil, it just got overheated? I have no idea why. Can any body help? PLEASE!
