fredbear241
- Joined
- Oct 1, 2001
- Messages
- 24
Is it possible to 'bypass' the Kubota ignition unit on a single cyl engine & use a 12v Automotive Coil? I'd still need something to replace 'points' and act as a 'switch'....any ideas? The flywheel has a magnet, the existing coil is there, there is a lighting coil inside the flywheel..... I suspect the orig coil might be cause of starting problem & wanted to test by bypassing it.
TIA for any input - Fred
