128 Owner - Need 44C deck swap advice
   / 128 Owner - Need 44C deck swap advice #1
Lscman
Cub Cadet Original,106,128,149
I own two Cub Cadets (128 and 149). Both have rusty 44" decks with manual lift. As you probably know, these models were the earliest wide frame design. From what I can tell, Cub Cadets of that era came with the first (earliest) 44" mower that is somewhat different than later 44A and 44C.
Anyway, I just drove 14 hours to fetch a brand new 44C deck. It came complete with the 44C mower support assembly (mule drive and arched deck lift frame).
Should I adapt an old 44" deck frame to fit the new 44C deck or should I try to adapt the newer 44C mower frame assembly to fit my early tractor?
The only precautions I found through searching were to stay away from the taller, high vacuum GT decks (newer than 44C) because they will not fit under the older tractors.
I understand there may be an issue with mule belt width & I'm not sure how to best address it. I think my PTO used a thinner belt compared to a 44C tractor. Perhaps I need to swap the center pulley on the 44C deck or something.
Any thoughts greatly appreciated.
   / 128 Owner - Need 44C deck swap advice #2
i think you should sell the tractors as they are and buy 2 new ones
   / 128 Owner - Need 44C deck swap advice #4
That is about the only real difference between the 44A and 44C decks- the 44C has the center pulley to use the 5/8" wide PTO belt, the 44A will have a pulley for the 1/2" belt. You can easily just switch the pulley. You will have to adapt the mule drive or the deck to be able to use the 44A or C with your tractor as it predates these decks, people have done it and from what I gather it's not too hard.
-Fordlords-
-Fordlords-
That's great help, thnx. I see the center spindles are the same on 44A and 44C which should make swapping the pulley a non-issue.
Now I need to confirm the physical differences between the early 44 deck that came on my 128 & 149 tractors compared to the later 44A deck. I understand they're not the same either.
UNUSED FUTURE 1 SHANK RIPPER (A57193)
UNUSED FUTURE 1...
2014 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2014 Ford F-150...
2007 Volvo VNL Truck Tractor (A55315)
2007 Volvo VNL...
UNUSED FUTURE MINI EXCAVATOR GRAPPLE (A57193)
UNUSED FUTURE MINI...
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
Pallet of 3' LED Lights (A56469)
Pallet of 3' LED...
