1250 Vs 1433
/ 1250 Vs 1433 #1
Tim_Ternest
Looking at two tractors
1-1250 with a loader
2-1433 with a loader
Is there a bid difference between the two? I was told they had the same motor and HP. The hood will raise on the 1433. any thing else between the two. (controls, elec, features,lift , pto, gearing)? thanks Tim
/ 1250 Vs 1433 #3
I have a 1433
it's quite a bit bigger tractor than a 1250
if i had a choice, i'd go 1440, same tractor, turbo'd motor
but, i do like my 1433
/ 1250 Vs 1433 #4
As Scotty said, you may get quicker information on the Massey forum.
That said, I believe the 1250 is an older series than the 1433.
/ 1250 Vs 1433 #5
I had a Massey Ferguson 1250 that I purchased new and owned for 10 years. I had great luck with the tractor and it worked well for me. I sold it last week as my usage required a larger tractor. I would not hesitate to purchase another!
/ 1250 Vs 1433 #6
The MF1433 was the replacement for the MF1250. I owned a 1250 for several years and now own a MF1440. Everything is easier to get to on the 1433/1440 than on the 1250 except the manual PTO lever. The lever really doesn't make any difference because when you hook up the implement you can shift it. Let me explain that a little. The 1250 has the lever to beside the seat and to the left kind of behind you. The 1433 has the lever by the three-point hitch. The button on the steering column is what turns the PTO on and off, the lever just activates the rear PTO. Both tractors use almost the same motor with the 1433 having a little more advanced version. The weights are also about the same. If you have any specific questions feel free to ask.
2003 30ft Rinker Captiva Boat w 2017 30ft Tri-Axle HMDE Boat Trailer (A66738)
2003 30ft Rinker...
Tow arm attachment (A64194)
Tow arm attachment...
2008 Ford E-250 Cargo Van (A66736)
2008 Ford E-250...
220 VOLT 6IN SUBMERSIBLE PUMP (A67714)
220 VOLT 6IN...
Unused 2024 Land Pride PF1242 42. Forks and Frame Skid Steer Attachment (A66734)
Unused 2024 Land...
Baby Goat Decorative Statue (A66738)
Baby Goat...
