1250 slipping
/ 1250 slipping #1
Tim_Ternest
I BELIVE MY 1250 HAS A SLIPPING CLUTCH. I ADJUSTED BY THE MANUEL. NO HELP HOW BAD IS THE JOB OF GOING INTO THE CLUTCH AND R&R THE CLUTCH. THANKS TIM
/ 1250 slipping #2
It will have to be split between the transmission and engine. The steering and dash can stay with the engine half. If you take your time and watch what you are doing it isn't to bad of a job. It will take a few hours. Be sure to block the front axle pivot on each side with a wedge. I have always used two wood wedges. It needs to be done on a concrete pad and is much much easier if you have floor jacks. I guess it is a dry clutch model?
/ 1250 slipping
Yes, its dry and thanks for your advise.....Tim
