1220 Information
   / 1220 Information #1
BKM72
Dalton, Pa
Ford/New Holland 1220
All,
Recently purchased a 1220 with a belly finish mower and custom fabricated front plow mount with an ATV plow on a winch. 740 well taken care of hours. Not a speck of rust on the tractor or mower. Got it for 3000 (steal IMO)
I cut a 2-3 acre field a few times a year with it and I'm going to plow the driveway in the winter.
I don't have much information on it other than a serial number of UC24912, which I can't find for the life of me online as to which model year it is. Any help with that would be beneficial. My questions thus far...
From what I can see, 5-40 engine oil?
Where can I buy parts for this tractor? Any good websites?
Looking to get a brush hog attachemnt eventually - is a 48 inch as big as i should go?
Thanks for you help in advance!
   / 1220 Information #2
Partspring.com is a good parts source as well as any local dealer. Tractordata.com should be able to help with your serial number. You really should get the owners manual. It will answer 99% of your maintenance questions.
On the brush hog, 48" would be the max...and that is if it's a lighter duty one like King Kutter. Heavy duty ones, even in 48", can get pretty heavy.
I have, and still use a 1986 1210. Great little tractor for jobs that you don't want to make a big foot print. I also have a 1710 but don't mind using the 1210 for a lot of projects.
   / 1220 Information #3
I believe the model year is 1990. You can see a list of model years here: TractorData.com Ford-New Holland 1220 tractor information
I agree with sld...48 inches max on the brush hog. I really like my 1220, but had to buy a bigger tractor for a 5 foot rotary mower. Finding a use 48 inch brush hog is not easy (I've tried!) -- you can buy a new one but they are expensive.
For engine oil, I use 10-30. The manual does not specify a suggested oil, and just gives the usual breakdowns of oil vs temperature you will be using it.
Mini Excavator Quick Coupler (A55272)
Mini Excavator...
2018 Ford F-150 Pickup Truck (A56858)
2018 Ford F-150...
golf cart (A55758)
golf cart (A55758)
2019 Freightliner M2 106 Johnston VT651 8.5 Yard Street Sweeper Truck (A56858)
2019 Freightliner...
550 GALLON FLAT BOTTOM POLY TANK (A58374)
550 GALLON FLAT...
2008 Ford Fusion SE Sedan (A54815)
2008 Ford Fusion...
