Rear Finish Mower 1215 & rear finish mower
   / 1215 & rear finish mower #1
Deaf
NE Ohio
Ford New Holland
Input needed
I have a Ford New Holland 1215 hydro 4x4 FEL with 1030 hours. I was wondering what all your thoughts are in regards to using this tractor with a rear finish mower. Currently the tractor is used at our hunting camp (trailer each time) to keep ATV’s trials cleared and brush hog small food plots and fields. In 2 years I have put 120 hours on it so it’s not getting used as much as I would like. We are in the process of closing on another home that has a ½ acre lot, most of it in the back yard and wanted to use the tractor as an over sized mower. I would remove the FEL and store it since it’s rarely used. Do you think the 1215 would be to big and heavy for this use? I can get a rear finish mower for $1100. The Cheapo lawn tractors are abut the same.
Deaf
   / 1215 & rear finish mower #2
Afternoon Deaf,
I dont see a problem with using that tractor with a finish mower on a small yard. That tractor is quite small only about 1400 lbs so weight is not an issue. As long as you think it will be manuervable enough on that lot I would run with your idea ! :)
   / 1215 & rear finish mower #3
Mornin' Deaf,
I think your tractor would work well on your lot with a RFM. I would get a mower that would fit around trees and plants in your yard. I just got a 6' finish mower, but I'm cutting 3 acres. I believe $1100 on a finish mower is better spent than on a disposable riding lawnmower any day.
   / 1215 & rear finish mower #4
I'm guessing the mower is a 5' unit (for $1100).
I'd use the tractor for mowing your yard. I use a Deere 790 for mowing my 1 acre of lawn every week or so during the mowing season. The 790 is 24 PTO HP annd is overkill for a 1 acre lawn. However, it's my lawn and I'll mow with what ever I want to mow with!
Of course, mowing is just one of this tractor's tasks. Overall, it's a good fit for my property and chores (maybe a bit big...but one of these days I'll buy that chipper!)
Enjoy mowing your lawn!
   / 1215 & rear finish mower #5
Deaf:
Go with the RFM. Jay
Thanks guys!
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
Heavy Duty Skid Steer Auger ECAG W/ 6", 12", and 14" Bits (A47384)
Heavy Duty Skid...
2013 MACK (A50323)
2013 MACK (A50323)
2004 International 7500 HT530 (A50323)
2004 International...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
(1) 250 GALLON POLY TOTE W/ CAGE (A51244)
(1) 250 GALLON...
