Bird, look at the nameplate amperage draw at 120V and then 240V on switchable voltage motors. For example, if a compressor motor that is 120V/240V draws 12 amps at 120V, it will draw 6 at 240V. Whether its 12 X 120 or 6 X 240, the wattage is the same excluding efficiencies. As you know, once you take into account the run of wire from the electrical panel to the servicing outlet, through whatever cord you may add to the compressor, it will have a voltage drop. That drop will be higher as the current through it increases but minimized when larger condcutors are used. Is it a concern? Only if it gets excessive. Most devices can easily handle swings either way of about 5 volts. So for a 120V outlet that drops to 115V as a result of the air compressor turning on, you will be fine. I have found on my small Emglo direct drive that I will frequently pop the built in breaker on a cold morning. The solution, let the compressor run with zero head pressure until the oil warmed up or even better, use synthetic oil, problem solved. I now have 3 compressors. 1 Emglo 1.5HP direct drive 120V, one SpeedAire 1.5 HP beltdrive 120V and a IR 5HP 240V 80 gallon beltdrive. As much as I like the IR 5 HP 80 gallon, my potential new place won't accomodate it, its for sale and almost brand new. /forums/images/graemlins/frown.gif
