12 v cig adapter not working.. Any thoughts?
/ 12 v cig adapter not working.. Any thoughts? #1
gogojuice
Canada
Kubota
I have a 1 yr old bx2670 and the cig adaptor (12V) did work initially.
However.. I tried it today to use with my sprayer and it isn't working anymore.
Not sure where to start.
Like to hear your thoughts.
/ 12 v cig adapter not working.. Any thoughts? #2
fuse first
Check the wiring diagram
Blind "probing" is a waste of time. get accurate info.
/ 12 v cig adapter not working.. Any thoughts? #3
Jiggle and wiggle the plug a bit.
Most cig adapter plugs that I have had are often cantankerous.
Also be sure that socket is tight as the ground could be bad.
I took the cig adapter that I am using out and tried it on my car. It works fine.
So my thoughts are it must be on the kubota end.. somewhere :(
/ 12 v cig adapter not working.. Any thoughts? #5
As it has been said verify power to it and I would check fuse first as was mentioned if you have 12 volts check and make sure it has a good ground try something else in power port to see if that works might have other than power port problem
Thanks for all your help. I scrapped the melted plug out and it still didn't work. Took a look at the fuse and thought it looked ok.
Didn't work.....so I just replaced the fuse and it works.
I must have missed the break in it. Only thing I can think of
Thanks again for all the help
Poly Machine & Parts (A64047)
Poly Machine &...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
Bobcat 709 Backhoe Attachment (A64047)
Bobcat 709 Backhoe...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
17395SFL (A61568)
17395SFL (A61568)
