12 pin to 6 pin attachment connector
   / 12 pin to 6 pin attachment connector #1
overseas
ohio
2000 Exmark Lazer Z Fuel injected Spec #PS78511
I have a 763H & I purchased a Bobcat stump grinder. My 763H has a 14 pin attachment connector & the late model stump grinder has a 7 pin connector. Does anyone make a harrness to convert the 14 to 7 pin connector?
   / 12 pin to 6 pin attachment connector #2
I have the small plug on my Toolcat and a large plug on an attachment. I was told yesterday by Bobcat that I would have to change the wiring on the Toolcat. I think somone is wrong and there must be a way to change back from the large to the small.
   / 12 pin to 6 pin attachment connector #3
I'm not 100% sure but I think the 6 pin and the 12 pin are not compatible so a conversion does not work. I believe you need to get the other harness. Which kinda sucks cause they are not cheap.
   / 12 pin to 6 pin attachment connector #4
Check out the Toolcat forum. I suggest going there and searching on this topic as it has been flogged repeatedly.
2014 Dodge 5500 4X4 Bucket Truck (A53472)
2014 Dodge 5500...
ITEM LOCATION LOT NUMBER 3 (A53084)
ITEM LOCATION LOT...
2008 Ford F-450 Crew Cab Service Truck (A52377)
2008 Ford F-450...
KUBOTA M6800 TRACTOR (A51247)
KUBOTA M6800...
UNUSED WOLVERINE QUICK ATTACH MOUNTING PLATE (A51248)
UNUSED WOLVERINE...
Grove 4x4 Rough Terrain Hydraulic Crane (A51691)
Grove 4x4 Rough...
