12 HP Kubota pressure washer
   / 12 HP Kubota pressure washer #1
MaltbyMower
Maltby Washington
Kubota B7100 HST/Kubota L4350MDT/John Deere L130
I don't know if it has ever been discussed, but why couldn't a mechanically inclined individual make a pressure washer that ran off the rear PTO on my B7100 tractor?
Let me know what you think.
   / 12 HP Kubota pressure washer #2
Of course, you can do that. I don't know of any pumps specifically for the PTO that put out quite as much pressure as the little power washers, but I have a 25 gallon stand alone "sprayer/washer" powered by a Briggs & Stratton that I use for insecticides. It has a gear box to reduce the speed of the output shaft from the engine to the pump, and the pump is a roller pump, exactly the same thing you can buy from Northern Tool or TSC for use on tractor PTOs. But it's only rated for up to 300 psi.
2022 Third Coast Reversible Plate Compactor (A51573)
2022 Third Coast...
40ft Pine Straw/Enclosed Trailer (A51572)
40ft Pine...
2016 FORD F-150XL SINGLE CAB TRUCK (A51406)
2016 FORD F-150XL...
2011 TRAIL KING LOWBOY TRAILER (A50459)
2011 TRAIL KING...
2018 Big Tex Tandem Equipment Trailer (A52384)
2018 Big Tex...
