Tractor Sizing 1100D - Tire Size
   / 1100D - Tire Size #1
CShipman
Have an 1100D. Anyhow, while doing a complete maint overhaul, my neighbor (who had used the tractor more then me) decided to take my front tires and have them replaced as "payment". He got some really good tires, /forums/images/graemlins/smile.gif however, they are 6.00-12, and rub against the goofy NUCO FEL /forums/images/graemlins/blush.gif front bracket, even with the wheels reversed. Anyhow, long story short, I need to get the CORRECT size tires, so, anybody know what that should be? /forums/images/graemlins/confused.gif 5.00-12? Thanks!
   / 1100D - Tire Size #2
Hoye sells 5-12 ag tires.
or
I bought a new set of 5-12's with the wheels off ebay for a JD 4110, which are identical to the tires on my F15D, which should fit your 1100D. I think the listing is still active with two sets left. Below is a link to my original post. It has the link to ebay.
5-12 Wheels & Tires
Attached is a print for the bolt pattern and center hole in case you are interested. (I'm an Engineer, what can I say)
Tom
  • 850846-FWHEEL.pdf
   / 1100D - Tire Size #3
I have to check my 1110, but I thought I had 10" rims up front. 5-10's up front and 7-14's in the rear. The 1300 series has 6-12 rims up front and 8-16 in the rear.
   / 1100D - Tire Size
I would appreciate the information cause even the 12 "nick" the frame for the FEL and that might explain the issue! Thanks!
   / 1100D - Tire Size #6
I checked and I have 4-10 fronts, not the 5-10 that I posted. The size for the 1300 front was an inch off too.
Can I see some pics showing how your loader is mounted?
   / 1100D - Tire Size #7
There are some 5.00x12 on ebay now (item# 7516407960)
2021 New Holland P2350 Air Cart  New, Tow-Between, Intellirate Control, Dual Tires (A51039)
2021 New Holland...
Ford F-450 Utility Truck (A51039)
Ford F-450 Utility...
2019 TAEKUCHI TL8 SKID STEER (A51242)
2019 TAEKUCHI TL8...
1998 CATERPILLAR IT28G WHEEL LOADER (A51242)
1998 CATERPILLAR...
2006 Volvo VNL (A51039)
2006 Volvo VNL...
2025 78in Dual Cylinder Hydraulic Grapple Rake Skid Steer Attachment (A50322)
2025 78in Dual...
