'11 M7040 HDC
   / '11 M7040 HDC #1
Tx Jim
New Member
Coyote Flats,Tx
JD 4255/Kubota M7040 HDC
I just took delivery on a used 2011 M7040 HDC(142 hrs on tach) that has NO operators manual. Does anyone know what I need to adjust so 3pt clears pto drive shaft on a pull type hay cutter. I pulled up on the 3pt draft links and they rose about 6-8 inches so I know rockshaft cylinders aren't at their upper limit. Thanks,Jim
   / '11 M7040 HDC #2
Hook your lift links arms to the hole closest to the tractor on your lift arms for maximum lift heights; there are three holes.
   / '11 M7040 HDC #3
There is an adjustment rod that may help. If I remember correctly, lengthening it will allow the 3PH to raise higher.
Test if you adjusted it too far by lifting the 3PH to the top and try to use the FEL.
Edit: Forget the attached thumbnail. It doesn't relate.
   / '11 M7040 HDC
gwdixon
Thanks for the photo. I'll try to adjust the turnbuckle today.
Jim
   / '11 M7040 HDC
gwdixon
I adjusted the turnbuckle per your instructions and the 3pt rose high enough to clear the pto on the towed hay cutter. Thanks,Jim
   / '11 M7040 HDC #6
That's what we are all here for. Share a little, learn a lot.
TBN is a nice place to frequent.
2007 HYDRO-AX 764 MULCHING MACHINE (A51242)
2007 HYDRO-AX 764...
2021 Dosko 337S-13HC Walk-Behind Stump Grinder (A49461)
2021 Dosko...
2009 PETERBILT 388 TANDEM AXLE DAY CAB (A51219)
2009 PETERBILT 388...
2019 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A50323)
2019 Chevrolet...
2019-2024 Dodge Ram Front Bumper (A49461)
2019-2024 Dodge...
2021 Case IH Magnum 240AFS CVX Connect MFWD Tractor (A50657)
2021 Case IH...
