11.2 tires on 12" rims?
   / 11.2 tires on 12" rims? #1
johmarq
Yarra,NSW,Australia
1951 Ferguson Tea20 & 1968 Massey Ferguson MF135
Hi All,
My rear tires are worn out and need replacing, they are 14.9 - 24 running on 12" rims
I have a near new set of 11.2-24 tires , my question is will they fit on the 12" rims?
and is it safe to do so?, any drawbacks in doing this?
The tractor is only used for cutting grass.
Thanks, John
   / 11.2 tires on 12" rims? #2
If they are tubeless, it might be hard to seat the bead. Try a ratchet strap or a come-along around the tread.
   / 11.2 tires on 12" rims? #4
Yep, as Rick said, they'll work fine. If tubeless you may experience the problem Xfaxman described.
   / 11.2 tires on 12" rims? #5
One thing you might have problems with is them coming off the bead in a turn if you don't over inflate them. Like the stretchies on cars operated by people of dubious intellect, the natural reflex of the tire will be to spring away from the bead.
   / 11.2 tires on 12" rims? #6
Can you explain how turning would cause that to happen on rear tires?
   / 11.2 tires on 12" rims? #7
Side thrust from inertia on a sidewall with insufficient pressure to keep it on a bead it was never intended to reach. Probably not an issue on a mower, and definitely not a safety concern. I only mentioned it because those tires usually have a pretty low operating pressure.
   / 11.2 tires on 12" rims? #8
Yep, I knew it could happen on the front and under inflated tandem axle trailer tires.
Just never had it happen on a rear tractor tire.
   / 11.2 tires on 12" rims? #9
   / 11.2 tires on 12" rims? #10
Hi All,
Thanks, John
Consider that the rim flanges will stick out beyond the tire. Not an issue unless you end up skimming against an occasional solid object.
NEW Wolverine 72'' Skid Steer Tiller (A53002)
NEW Wolverine 72''...
WESSEX 1.5T LOT NUMBER 172 (A53084)
WESSEX 1.5T LOT...
2001 CHEVROLET TOW TRUCK (A52472)
2001 CHEVROLET TOW...
WB Mower (A50120)
WB Mower (A50120)
2017 MITSUBISHI OUTLANDER SPORT (A52472)
2017 MITSUBISHI...
2013 Dodge Charger Passenger Car, VIN # 2C3CDXAT6DH646717 (A51572)
2013 Dodge Charger...
