10x14 or 10x16
   / 10x14 or 10x16 #1
lovemytoys
andes ,new york
bx24
looking to build a shed just for lawn mower, snowblower and odds and ends.was thinking of pouring a 4 inch slab .could i pour on dirt or do i need gravel and vapor barrier?
   / 10x14 or 10x16 #2
You can pour on dirt but most of the time people pour on sand because it doesn't require any compaction and it is easy to level.
   / 10x14 or 10x16 #3
I've poured a couple of slabs right on the ground. One for my sawmill that I formed up with scrap steel tubing, and the other was un-planned. My block guy over estimated my house footer pour and instead of sending 3-4 yards back, I quickly cleared out a shed and just dumped it right on the ground without even a form. Neither one has a vapor barrier and if it's always going to be an open shed you don't need one.
I park my tractor on non formed slab and have only had some cracking where the slab feathers out into the yard.
   / 10x14 or 10x16 #4
Ever think about 2 x 6 PT joists on concrete blocks? Quick, and if you ever want to move it, no problem. I get nervous about concrete on anything but crushed stone or good gravel-not loam.
Couple of picks of a 10 x 12 I did last fall. I'm going to do another one shortly for same use as you described. Note, I dug the loam out under the piers and replaced with crushed stone.
   / 10x14 or 10x16 #5
If it is natural undisturbed land, I would feel fine pouring on the ground for such a small footprint and lightweight use. You may want to consider a small footer and maybe a small "beam" footer in the middle. I would certainly use enough rebar.
Redhorse brings up a good point. Depending on your expected maximum weight load, it may be beneficial to have the ability to move it later, but that size would be a chore.
Also, check and see what the "tax" status would be, some only taxed fixed structures, some wont tax a portable shed. Where I am they tax everything so YMV
   / 10x14 or 10x16 #6
When I was young I worked summers for a modular building company that also made sheds, and doing a framed floor supported on cinder blocks was the preference. This allowed us to pre-fab the buildings of course, but was also better for dealing with oddball sites, frost/ground issues, etc... It eliminated the possible complexity of leveling the site or pouring a slab, which is frequently an issue in residential yards. Over time, you could always adjust the blocks with shims to account for any changes.
For light equipment (say up to a riding mower or garden tractor) you can get away with 2x4 floor joists spaced 12" with 3/4" plywood decking and 4x4 skids under the joists (the blocks then go under the skids). Go up to 2x6 for heavier loads.
I attached a picture of an example shed.
   / 10x14 or 10x16 #7
I just poured a 15x20 slab last Saturday... I had to use sand as fill because the ground wasn't level on the back... I also put plastic down on top of the sand.
I'd say build a 10x16.:)...Never can have enough room for tools!!!;)
Bill
   / 10x14 or 10x16 #8
I'd say build a 10x16. Never can have enough room for tools!
Besides, a 16' will involve one less panel cut on your sheathing. You're basically getting another 20 SF for the cost of two sheets of ply (when you count the roof too).
Don't forget you can go up, too. 10' walls look nice on a 10x shed, and you can put a lot of stuff in a loft. With a rafter framed roof you could even stand in the loft. If you wanted to go as high as 12 a gambrel roofline would let you bring the roof 1/3 to halfway down the sides so it doesn't look as tall. Even if it's just for garden stuff, it's nice to be able hang fertilizer spreaders and such overhead for more floor room to move around. Just a thought.
Oh, and add windows up high or a band of clear siding. Being able to find stuff without a flashlight is nice.
   / 10x14 or 10x16
thanks for the input i was think barn gable roof?? i think thats what it called with 6 ft walls ,i don't want it to look to out of place .after this a 20x30 home for the tractor maybe be 20x40 i also have a 20x30 garage which I'm looking to take stuff out so i can park in there during the winter
   / 10x14 or 10x16 #10
Definitely a vapor barrier. So cheap and you can't add it later. Bank sand works great to help level and you won't need much. I vote 10 x 16.
Use #3 rebar on 16 inch centers and thicken the edge perimeter. Just a little beam 8inches wide and 8" deep (includes the 4" slab). I would at least do 8 foot walls. 6 foot is just too low even if you vault. And doors are always a minimum of 6'8".
I'm with you on the concrete versus framed floor. No ramps and at ground level.
Chevrolet C8500 Flat Bed with a Moffet Kit (A55218)
Chevrolet C8500...
2004 TerraGator 8104 (A55301)
2004 TerraGator...
2022 CATERPILLAR 242D3 SKID STEER (A51406)
2022 CATERPILLAR...
2000 CATERPILLAR 140H MOTOR GRADER (A51406)
2000 CATERPILLAR...
