$10K Question ...... Literally!
   / $10K Question ...... Literally! #1
Haoleguy
Platinum Member
SE Connecticut
JD 5325; Landini Mistral 50
I have a good friend that has horses and loves to ride daily. Up until now she has ridden on a network of paths near her barn. At this time she is looking to trailer her horses(2) to other riding networks in the northeast on day trips. Her trailer, horses, and stuff will bring the trailer weight up to ~5500 lbs give or take a few. She will be in need a tow vehicle to replace her commuter car. With a budget of $10K to find a good reliable tow vehicle it caused me to scratch my head a bit as the trailering weight hits near the limits of the 1/2 ton trucks from the early-mid 2000s. What do you think would be good choices? I was thinking an 2002-4 F250 5.4 gas V8 as they are kind of in between what people normally look for and may have the trailering package from the factory. All thoughts welcome.....Cheers
   / $10K Question ...... Literally! #2
Get a Suburban or Expedition. Then she/you can sleep in the truck and you can get away for more than a day. My Tahoe pulls my trailers (boat and hay delivery) easily and jumps into DOD (Displacement on Demand = 4 cyl mode) while going 70 on the motorway. That's 22 - 24 mpg (gasoline, not 15% ethanol) based on the Instantaneous Mileage readout on the dash. I believe truck weight limits are worst case for the idiot that actually pulls twice the rating. Its brakes and transmission temperature that are the principle concerns in actual use. If you have good tires (especially on the trailer) and a good floor, and you keep your speed reasonable, a 1/2 ton truck can be expected to do the job reliably.
A 5th wheel horse trailer and P/U truck combo is also a local favorite. That rules out the SUV option, though.
Yeah, its just my opinion but based on everyday use and service factors.
Results may vary, some people can't sleep in a truck, some drivers may not be able to hitch up or back up a trailer, many can't measure tire pressure, some horses may not want to go into a trailer, but there's an App for that...
   / $10K Question ...... Literally! #3
About 18 months ago, we bought a 2004 Silverado 4 x 4, Z71, 1/2 ton, std cab. I replaced the factory hitch with one that has a 10,000 pound tow rating which is overkill for the truck. However, I wanted plenty of safety margin on the hitch. Our 2 horse bumper pull trailer, with dressing room, weighs 3,400 pounds and with 2 horses aboard we're around 5,500 - 5,800 pounds. The factory hitch was (I think) rated at 5,000 pounds. I also had a Maxbrake brake controller installed so she doesn't have to worry about adjusting the controller based on the number of horses.
This 1/2 ton Silverado, with the aftermarket hitch, has enough power and capacity to handle 2 horses in our trailer. I wanted a truck with an 8 foot bed (for getting hay) and 4 x 4 and set a budget of $10,000 (again, this was 18 months ago). This truck met those requirements. Finding a truck with an 8' bed around here was difficult. Plenty of 6.5' beds with extended or crew cab, but 8' beds were hard to find. I found a 2002 Ford, 1 ton, SRW, 4 x 4 with an 8 foot bed, but it also was a crew cab. My wife took one look at it and said, "Wow, that's a LONG truck.". We were considering it, even though it was 2 years older, but I couldn't get the dealer to call me back.
   / $10K Question ...... Literally! #4
5,500# is nothing. I had early 2000's 5.4L 4x4 F-150's with 3.73 gears that were rated to pull in the 8,500# area. As said before any 1/2 ton V8 with proper gearing from any of the 5 manufactures is plenty. Full size SUV like the Expedition and the Suburban is also a good match. While a mid size may have the tow rating to do so I would skip it. The frontal area of a horse trailer will really work the tranny on these trucks. My mechanic did in his Jeep with a Hemi pulling a horse trailer and also boiled out the fluid in his V8 Mountaineer doing the same thing. He caught it quick enough on the Mountaineer to save it. He refuses to get a bigger truck though.
Chris
   / $10K Question ...... Literally! #5
My first tow vehicle was a '90 F150 with the 4.9 six and 3.08 gears, the factory tow rating was 5,000 pounds and after I added a secondary trans cooler, a Flowmaster cat-back exhaust system, and a secondary cooling fan in front of the radiator, it did respectably well at towing a 6400 pound loaded TT. I never really needed more power, and it would stop the combo okay, yet I always babied the truck because it was over the tow rating.
Upgraded to a 3/4 ton Yukon XL, the peace of mind not having to worry about breaking something made towing a lot more fun...I don't think I would ever be comfortable towing a near 3 ton load with a half ton truck again. Odds are, down the road, your friend will want to haul more than the 5,500 pounds you mention. If that is a remote possibility, get a 3/4 ton chassis vehicle. Just my nickle's worth.
   / $10K Question ...... Literally! #6
I also swapped out the instrument cluster on my 2004 Silverado with one that had a tranny temp gauge. Fortunately, it was a 'plug and play' operation. I found the guy on eBay. I've told my wife to always keep an eye on the gauges, particularly the coolant and temp gauges.
   / $10K Question ...... Literally! #7
Chris
I have the same setup 2003 F150, Supercrew, with the 5.4 ,4 spd OD, the HD trailer tow pkg. It handles my 6000 lbs travel trailer like nothing, hualed all over the Adirondek mtns put it in cruise and go. My old dodge 2500 conversion van with 318 used to struggle with it never could pull it in cruise control.
So that setup will work really well for you. And we get 14-15mpg all around and 10mpg towing, really not bad.
   / $10K Question ...... Literally! #8
Our first PU to pull our 2 horse BP trailer was a 1994 GMC 1/2 ton with the 6.5 turbo diesel. It was a great truck, we traded it in on the 2003. Look at Autotrader for examples, you can get a 3/4 ton diesel of any brand at that price, early 2000s and before. For a little more, say $15K, you can get a really nice truck. Then it will pull the 2 horse trailer or bigger when she trades up (which usually happens). We now pull a 3 horse slant load GN, 7 1/2' tall, 8' wide with both trucks.
   / $10K Question ...... Literally! #9
Mike, my 3/4 ton GMC had the dash with the trans temp gage...are you telling us that GM put the trans sensor, wiring, etc in your Silverado and all you had to do was buy the dash cluster to have the temp gage operational? Thats something I am sure a lot of owners wish they knew.
   / $10K Question ...... Literally! #10
Add a weight distributing hitch and almost any 1/2 will tow 7500lbs.
2017 Mack Pinnacle CHU613 Day Cab Truck Tractor (A53117)
2017 Mack Pinnacle...
2005 DIVERSIFIED FABRICATORS FERTILIZER SPREADER (A51247)
2005 DIVERSIFIED...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
THRESHOLD 30" SQUARE OUTDOOR GAS FIRE TABLE (A51248)
THRESHOLD 30"...
2018 Suzuki KingQuad 750 AXi 4x4 ATV (A51691)
2018 Suzuki...
40 ft. Shipping Container (A53117)
40 ft. Shipping...
