10ft rotary cutter on a 4x20?
   / 10ft rotary cutter on a 4x20? #1
trook
North Central Mississippi
JD 5075E Cab
Is anyone out there using a pull behind 10-ft rotary cutter on one of the 4X20 series compacts? I know most of the 10-ft cutters require about 40-50hp at the pto as a minimum, and the 4520 and 4720 meet/exceed those requirements. Will this combination work as long as the terrain is not overly hilly and the grass is not too overgrown?
Assuming a FEL is attached, do you think the 4x20 frame also has the weight to handle the pull behind 10ft cutter so that the "tail does not wag the dog"?
I realize that a larger frame tractor would be best, but I would like to keep my current attachments, and I like the maneuverability of the 4x20 machines.
Oh yeah, I currently own a open station 4320 and am considering upgrading to a 4720 cab. I maintain 75 acres that is a combination of open land and woods. I also work on the side when I can to help make my tractor payments.
   / 10ft rotary cutter on a 4x20? #2
a 45 to 50hp tractor will pull a 10ft shredder with ease.i would get a 10ft pull type.3pt lift is to much weight tobe lifting.
   / 10ft rotary cutter on a 4x20? #3
Some 10' cutters are heavier than others and will cut thicker stuff. The manual will tell the PTO power required.
We pull a Woods DS1260 with a Kubota M8540 in fairly steep hills which would present problems for a lighter tractor with less HP, but on flat land, you should be able to do this with a smaller tractor though for the DS1260 it is at the very bottom for PTO power. Woods and others make lighter duty 10' cutters with less HP requirements I am sure.
We have a Woods 121 10' 3-point and the 1260 is pull type.
   / 10ft rotary cutter on a 4x20? #4
As mentioned, look for a light weight/light-duty model and it might work. For reference, we pull a 1008 JD bush hog (10' 8" cut, pull-type) with a 65 PTO hp JD 2550, which weighs about 10,000lbs fully ballasted. Turning across a steep hill it will slide the back of the tractor if you aren't careful. Power is plenty adequate, but I wouldn't want any less in really tough going. Bottom line, a 10' pull-type cutter might work on a 4000-series JD, but they are meant to be used by much larger tractors.
   / 10ft rotary cutter on a 4x20? #5
I think "radman1" is running a 10footer with his 4520. Hopefully he will check this thread.
   / 10ft rotary cutter on a 4x20? #6
I think you can run a light to medium duty 10' cutter with a 4720 as long as the terrain permits. I would want to try it out to make sure your pto can engage properly though, as you know the electric pto engages kind of fast.
   / 10ft rotary cutter on a 4x20? #7
you can always leave the toplink off a 10' 3pt cutter and run it like a semi mount, like a jd mx10.. etc.. I have a howse 10' 3pt cutter.. it's a beast.. but is heavy.. think it weights 2450 or 2800#.. something like that. ( pull it with a ford 5000 67 pto hp )
soundguy
   / 10ft rotary cutter on a 4x20? #8
I pull a 8' twin spindle shreader with my 4610 - its a good match. I would not hook up to the howse 10' though with the 4610.
but that just cause I got a cab 3140 to pull that howse:)
turing the blades wont be a problem but its alot of deck behind ya.
like they have said dont try to run it as a 3 pt - either get a true pull type if you dont have transport issues or follow the directions to make it a floater. That way if you just do happen to wack into something you wont tear-up your tractor.
mow on Brother, mow on!
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50324)
2018 Toro Grounds...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
71067 (A49346)
71067 (A49346)
2007 INTERNATIONAL 4200 SBA 4X2 DUMP TRUCK (A50459)
2007 INTERNATIONAL...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
2004 GREAT DANE 53FT REEFER TRAILER (A52141)
2004 GREAT DANE...
