(1066) What size are the plugs for draining?
   / (1066) What size are the plugs for draining? #1
Richard
Super Member
Knoxville, TN
International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
1066. Has a female pipe plug (if I have the correct name) to drain the hydraulic fluid. (I've actually not even looked at engine oil yet!)
I used my 1/2" ratchet with nothing attached to pull two of them off. As I understand, there are five of them. (I've not yet dealt with the axle drains) the one that has me scratching my head is the PTO drain.
The 1/2" ratchet is too big.... the 3/8 doesn't fit either. The 1/4" is way too small.
Why did they put these female fittings in there? (doesn't matter, I'm just wondering out loud)
Anyone know what size of male pipe plug tool I need for this? I don't want to spend $50 (or more) for a set of them when I only need a single socket.
TIA
   / (1066) What size are the plugs for draining? #2
Make a plug removal tool. You have and old 1/2" drive extension or a 3/8" to 1/2" adapter. If so grind the 1/2" end down till it fits in the plug.
I don't have any beaters that I'd want to grind down so, I found & bought set of the correct tools!
Besides... in my opinion, it would take a LOT more time than it's worth to grind something down.... laying on my back under the machine...
Got all the plugs out today & hydro fluid is now changed!
AND, I have a set of new tools for the box!!
   / (1066) What size are the plugs for draining? #4
There you go, can't beat new tools for the tool box
Black Steel Diamond Plate (A55758)
Black Steel...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A55745)
2018 PJ TRAILER...
Tube Broom 8, 5/8 x 58 Poly 26" (A59076)
Tube Broom 8, 5/8...
Topcon RL-H4C Laser w/Tripod & Grade Stick (A59076)
Topcon RL-H4C...
2011 DOOSAN G25KW GENERATOR (A58214)
2011 DOOSAN G25KW...
