1042 no start
/ 1042 no start #1
strkpr00
My 6 mo. old CC1042 Kohler 19 hp Courage will turn over, has spark, has fresh fuel [full], pulled the gas line off and it flows, now last time out I ran out of gas and put a small amount of 3 mo. old "stabil" gas in the mower [getting ready for hurricanes] and have since then filled it with fresh gas and topped my car at the same time, the gas seems OK, I also could feel the backfire-solenoid click on the base of the carb.
Warranty? I am the second owner after the first guy bought too much mower for his yard. Cub Cadet and Kohler warranty is for the first owner only, this was bought at Lowes as a close out. any help would greatly be appreciated.
/ 1042 no start
while I had the air cleaner off I could see that the choke works, and it would backfire on occaision threw the carb while cranking. :mad:
/ 1042 no start #3
You need three things to run- Compression, spark at the right time, and gas.
We will presume you have compression, and you stated it has a spark. As it gets a backfire through the intake, it sounds like it is not getting enough fuel. (too lean) Try spraying some carburetor cleaner down the intake while attempting to start it. If the fuel system is blocked, it will usually run off the carb cleaner for a few seconds, and many times that will clear a blocked main jet if that is the case. If it does that but does not continue to run, check and see that the fuel filter is not plugged and that the fuel pump is working. I would then verify that fuel is indeed getting past the shutoff solenoid down in to the float bowl. In essense, you just start troubleshooting each part of the fuel system one by one. I have used the Stabil product in a couple of my cars I don't drive in the winter, but tried it in a newer Kawasaki motorcycle last year and could then not get that bike to run to save my life. Only after draining out all the gas and refilling it did it start and run. I found the bast way to store small engines is to shut the fuel off at the tank and run the carb(s) dry.
-Fordlords-
/ 1042 no start #4
pull top and flywheel found several flywheel keys scheered on that model. kohler said bolt was not tight enough
/ 1042 no start
Fordlord if I disconnect the solenoid wire on the carb. bowl will that bypass that item?
/ 1042 no start
I pulled the solenoid wire, no clicking and no start, next I going to pull out the gas and try another source for fresh gas, maybe it doesnt like cheapo. I did shoot some solvent in the carb that we use to start diesels/ forklifts and nothing special happened. Is it possible for it to jump timing?
/ 1042 no start #7
Dont pull the wire off the fuel cutoff on the carb bowel. No power = no fuel. Is the sparkplug getting soaked with fuel? Have you verified a strong spark @ the sparkplug? Gotta start with the simple stuff!
Joel
/ 1042 no start
JTK when I pulled the plug and grounded it the spark was quite clear, and I could see vapor shooting out of the spark plug hole when cranking, I will try the lousy gas angle on Sunday when I get a top brand fuel, not the knock off stuff.
/ 1042 no start #9
If it did not fire using the starting fluid, I would check the flywheel key as 7254t mentioned, as if the key is sheared the ignition timing will be way off and cause the no-start.
-Fordlords-
/ 1042 no start
I hope thats it, changing the pushrod looks like a job.
/ 1042 no start
7254t, Fordlords, JTKub, thanks for all your help, got fed up and pulled the fly wheel and sure enough the was sheared, went to the Advance Auto parts store and bought a small set and cut one down to fit, when the weather cools off I will put the oem in, according to the Kolher web site the torque is 50ft lbs so I set it at 65, It started and ran til I shut it off and it did restart,:D Thanks again,
/ 1042 no start #12
Glad to hear that got it fixed :) I remember my first lesson on flywheel keys at age 10 when I hit a large rock with a push mower with 3.5 HP Briggs :)
-Fordlords-
2015 Caterpillar 304E (A64126)
2015 Caterpillar...
2017 International Prostar 122 Day Cab (A62613)
2017 International...
72"Skid Steer 4 in1Bucket (A62613)
72"Skid Steer 4...
2012 EAST 30' DUMP TRAILER (A64277)
2012 EAST 30' DUMP...
Yale Forklift - NO RESERVE! (A63688)
Yale Forklift - NO...
(4) ASSORTED TIRES (A62613)
(4) ASSORTED TIRES...
