Price Check 1026r
/ 1026r #1
gump1969
Got a quote for $16,800 loader and auto connect deck. The price is including roll off and set up. What do you think.
/ 1026r #2
I think that is an awesome price! You should pull the trigger on it soon, before the annual price increases hit.
/ 1026r #3
Good price if it's the H120 loader.
/ 1026r #4
the new holland equivalent is $14,500....
/ 1026r #5
New Holland now has a SCUT with a Drive Over Auto Connect Mower!?! And a Loader that lifts 836# to full height (over 72") at the pivot!?! No? The OP was asking about a 1026R, not a Boomer.
/ 1026r #6
um actually yes, it is 27hp, and the loader lifts 1,034# up to 80.7" to be exact.....and is a heavier bigger tractor...
/ 1026r #7
Your Boomer 1025 SCUT with the 210TL Loader lifts 662# at the pins to a full lift height of 69.6". And still does not have a Drive Over Auto Connect Mower.
/ 1026r #8
That was the old Boomer series you are referring to. JDBNH is talking about the new Boomer 25 SCUT which is really a LS tractor J2030H model. Have no idea if they are good or bad, but they look more like a pseudo-SCUT/smaller CUT than an actual SCUT.
/ 1026r
Just a little bit of my thinking, i have been looking at the x740-x720 and was thinking of putting pto and 3pt hitch on later. The main chore will be mowing but I like having a garden, and maintain the gravel drive. So the I will be demoing a 1026r this evening and If it will maneuver close to the x700 series, I will probably own one.
/ 1026r #10
yes you are right, thanks
/ 1026r #11
I can't speak for everyone else, but one test drive on that LS, a BX, a B, a GC, an 1816, Branson 2800, and a Deere 2320 is why I now own a 1026R. The Deeres are worth it.
/ 1026r
I'm struggling with my decision between a 740 and 1026, didn't plan on buying a loader but man the, with how easy it comes off, it is making me crazy and i'm making the wife crazy.
/ 1026r #13
That is tough. The x740 and 1026R are a long way apart in both price and capability. Choose very carefully the one that will fulfill your needs. By the way either one will be head and shoulders above a non current boomer 1025 NH.
/ 1026r #14
I picked mine up Saturday, 1026R, 54D auto connect mower deck and the H120 loader with a 60 inch bucket. Price was $15,580 here in Oregon, I sent out a request for quote via e-mail to all the dealers in my area and that was the best price found.
The dealer ran over the deck wheel mounting posts while demonstrating the easy on and off mower. Having seen that I would suggest the 60 inch mower over the 54 just because as you drive on or off your tires aren稚 as close to running over the anti scalping wheel assemblies.
/ 1026r #15
I'm curious to see if this will be a big problem or not. I'm looking into a 1026r and would go for the 54" deck because my land isn't level and the 60" would scrape a lot, I think.
/ 1026r #16
I went for the 60" deck, I figure if my lawn is too uneven at least now I have the perfect tool to fix it ;-)
/ 1026r #17
My 1026 was delivered today ( with less than an eight tank of gas).
Paid $12,100, H120 Loader $3000, 60" mech lift $ 2275, 54" blade $1250
/ 1026r #18
I've got the 60d on my 1026r & I've got some uneven terrain. I've got the wheels in the highest position on the deck and I've got the deck adjusted to it's highest cut setting. I cut in the float position & Im happy with the cut I get. Whenever I get to a high spot, I raise the deck. It took me a time or two to figure out my settings. I could see how the 54" could be a little easier.
/ 1026r #19
Considering a 1026r, 2720 or 3720. I have about 4 acres that I mow. Some of it hilly and uneven. I have been using a Badboy zturn that has a 26hp Kawazaki that mows fine. From everything I have been reading in the forums, maybe I should keep the BAd Boy for mowing and use the tractor for other chores. The comments I am reading here about deck height seem to indicate the deck will not go as high as the bad boy. We have had some good rain in the TX hill country this spring and my un landscaped acreage got pretty high. The BB handled it w little problem.
So my question is: what do y'all think about these sub compact tractors as field mowers?
Thanks, I am a forum newbie.
2009 IC Corporation PB105 School Bus (A60352)
2009 IC...
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
2007 John Deere 644J Articulated Wheel Loader (A59228)
2007 John Deere...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2015 Ford F-350 4x4 Ext. Cab Pickup Truck (A59230)
2015 Ford F-350...
KUBOTA L3901D TRACTOR (A59823)
KUBOTA L3901D...
