1025r scv
   / 1025r scv #1
Madarcher427
Michigan
1025r
I cannot get my quick connects to connect. I ve the scv lever several times & still cannot get them in. Any suggestions?
   / 1025r scv #2
Yes, very likely there has been some pressure built up in the lines and you cannot push hard enough to move that tip button back in the male end.
Wrap with a rag, and press or tap the tip against something hard, like steel, and the oil will squirt out (so be aware of that sudden squirt of oil).
That or loosen a connection in the line of the attachment to drain some oil and relieve the pressure.
This happens when the lines warm up in the sun, and the oil expands building some pressure. Doesn't seem to take much either.
2018 Vermeer Chipper (A51573)
2018 Vermeer...
2007 FREIGHTLINER M2 BOX TRUCK (A53426)
2007 FREIGHTLINER...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A53426)
2016 FREIGHTLINER...
2024 Wanco WCTS-SM4A-730 800W Solar Integrator Trailer (A51691)
2024 Wanco...
2010 Chevy Silverado HD Crew Cab (A52384)
2010 Chevy...
PALLET OF ARMSTRONG CEILING INSULATION (A51248)
PALLET OF...
