Mowing 1025R deck level question
   / 1025R deck level question #1
Garycw
Platinum Member
Oh-Ky-Fla
JD 1025R w/ fel, Farm Pro 2425, ford 841 & 851
Just delivered new yesterday. With deck set high it was still mowing too low. Dealer said they leveled deck.
I shortened the lift arm turnbuckles 7 full turns each. It did raise it higher and will still go into the lock position easily. I noticed that the bolt is coming through one of the turnbuckles about 1/4" more than other ? Is this normal? Or should they be the same?
   / 1025R deck level question #2
park on level surface and take a tape measure each corner of deck, you probably was given a mower deck manual with your purchase. That turnbuckle bolt could be longer than the rest
2003 Pierce Tilt Cab Pumper Fire Truck (A50323)
2003 Pierce Tilt...
2014 Dynapac CC4200 Tandem Vibratory Roller (A52748)
2014 Dynapac...
2017 Ford Fusion Sedan (A50324)
2017 Ford Fusion...
1990 International 8300 Vacuum Truck (A47384)
1990 International...
2012 Cadillac CTS Sedan (A50324)
2012 Cadillac CTS...
2007 Generac QT06030AVAN 60kVA Gasoline Generator (A50322)
2007 Generac...
